Hello, I have been in contact with a Mr Robert Miller of the above co. with regard to refinishing a dial. I have been unable to contact him since 21.10.15, an answer phone takes a message but no response. Has anyone heard anything that might explain this? Up to the date mentioned contact had been extemely good.
regards
Thanksgiving? Holidays? I don't know Harrison, I've never used them (although I'm about to) but over here you can't hardly find anybody anymore...it is that time of the year! Just a guess...
Cheers,
Bob
I recently had some dial refinished with them. The service took so long to complete. But they did it pretty good. They normally reply my requests thru emai. Sometimes they answer the phone, especially in the morning.
Hi All, International Dial contacted me 2 weeks ago to say the dial was done and they would post after payment (Paypal).It arrived today and looks good (see attached). I chose to have a "generic" finish similar to the original but not an exact copy, but with the ORATOR name, 17 Rubis, swiss made and antimagnetic printed. The hands are the elegant originals, a bit pitted. I finished the chrono hands in orange as I found them a bit confusing, as are the pushers, the start is at 1400, stop at 1600 and return at 1600, slightly non intuitive.
The watch has a Landeron 48 movement and is keeping good time, its gone from a basket case to nice watch, happy ending I think. post-1266-0-91020500-1453911751_thumb.jp
That's a smart looking watch you've ended up with Harrison, I really like it. The first chronograph I restored was a Landeron 48, that's why I have a soft spot for them.
I really like the style of this watch, great job.
Are the marking-extensions at 3, 6 and 9 minutes like the original? And what is the purpose for that? I only ask because I have never seen that before.
Yes they were common on old chronographs.
In the past telephone calls were charged in intervals of three minutes and the markers made it easier to time phone calls and get value for money. By that I mean if you went over three minutes by a second or two you were just as well talking for another two and a half minutes as you were going to pay for the next release minutes anyway.
that was a great choice on the dial finish. it is really beautiful. i love old chronos. they have such character.
on another note, i want to thank the OP for following up on this thread. i've been on other forums where you never hear the outcome. good on ya'.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
