2 hours ago, AndyGSi said:
Yes it does.
Question: can a chrome plating be regarded isolating?
But let the pusher be plastic, the device has even more safety issues, I found on 2nd look.
Some info on safety classes.
Buyers of such devices from china must be aware that they are regarded legally the importer (just like Cousins and others) - with all legal obligations. and liability.
10 minutes ago, RichardHarris123 said:
Plastic can be chrome plated.
Yes it can be but if they're keeping costs down then I expected it's either chrome coloured plastic or it is metal.
Maybe @neevo could let us know.
All this debate about the switch, and I'm wondering about the bolts that hold the coil in place. I think it's a stretch to declare it unsafe on the basis of a single photograph, but equally it's unclear from a single photo whether it meets the European/Australian requirements for a Class II or Double-Insulated appliance. I don't think the switch is a problem if it's switching low voltage. It doesn't look like the mains wires are long enough to touch the body of the switch even if they were to come adrift, and if they touch somewhere else they shouldn't the insulation of the switch will still protect the metal push-button so a single failure would not lead to dangerous voltages being exposed. The bolts holding the coil should be insulated from the body of the coil and its not clear from the photo whether they are. All up, though, you're far more likely to get a shock from your washing machine or dish washer than from this device.
More importantly, did you demagnetise your balance? How does it look now? I recently had a balance where the two outer coils were touching. I demagnetised and they immediately sprang apart to perfect concentricity.
Most demagnetizer circuits I've seen convert mains AC to DC and charge up a large value capacitor. It may or may not have a voltage doubler.
The switch disconnects the capacitor from the mains and connects the capacitor to the coil. The inductor/capacitor circuit ossilates and decays naturally.
So, the switch is definitely connected to high voltage.
I don't think there is any low voltage circuitry in this contraption.
Where is Prof @LittleWatchShop when we need him? I think he worked on a few of these demagnetizers before.
The button should energise the relay and led which means there must be some sort of resistive or capacitive dropper.
Anyone concerned about the electrical safety of this or any other tool might prefer to operate it via an RCD (Residual Current Device) safety switch.  These will detect any leakage to ground from the active wire of 30 mA or more,  and immediately shut off the voltage.
In fact,  since everything on my bench runs from a single outlet,  I plan to buy one myself.
There are many kinds but here is a link to one example. https://www.bunnings.com.au/arlec-single-outlet-safety-switch_p7050029
Obligatory disclaimer:  I am not an electrical engineer and this is not professional advice.
I don't see any relay in this.
1 hour ago, AndyGSi said:
The black box, otherwise what controls the charge and discharge of the capacitor?
If that's a relay, it's operating voltage can be anything from 3V to 230V.
I read the whole thread. Here are some thoughts.
Most (if not all) of the good demagnetizers operate on the same principle using the Villard cascade voltage multiplier.  I have serviced three or four--all branded "Vigor."  In every case the 4uF capacitor had died.  Will explain later. Comments below are all based on the Vigor.
- there is no low voltage anywhere in the circuit
- the push button is plastic mounted in a metal housing but I believe the metal is isolated (I will check later).
- the push button is connected to the highest voltage in the circuit.
- the transformer is not wired as a transformer and is simply used as a BFI (big freaking inductor).
- the Vigor is not powered using a three-wire cord with the third wire being earth ground.  I have no expertise in the regulatory stuff associated with "double insulated" etc. (I am a semiconductor guy...most of my life has been spent at 10V and below!!).  But, I don't think the Vigor meets the double-insulated requirements--my guess.
The units I have serviced, were completely rebuilt except for the inductor, switch, and neon bulb.  In all cases the 4uF cap had gone bad.  The reason is that the unit is continuously plugged and and you have the full rated voltage across the cap for the entire time.  Stress eventually wins the day.  Therefore, for all my rebuilds, I put an inline switch on the power cord.
Edited by LittleWatchShop
  • Thanks 2
All modern domestic wiring  installations in the last 20 years in the UK will have RCD protection. Still a lot of unprotected homes though mine included in some earlier circuits of my house. I run everything in my watchroom from 2 good quality plug-in RCD units, nice and close to all the devices and appliances I have in there. For the sake of 50 quid for these or replacing two sockets for two passive RCD sockets, reduces any potential electrical hazards .
Good tip👍about the in-line switch, I recently did just this with a permanently plugged in transformer for the power supply and speed adjuster for a dc motor that runs my rotary washer.
On 12/17/2024 at 7:28 PM, Neverenoughwatches said:
I think everyone has assumed it is Andy unless they know for sure, but it does look like steel, the casing at least. Does plastic come in a steel/chrome colour 🤔.......👍.......😅
Just checked. The switch is metal.
Also I haven’t demagnetised the NH35 yet as I lost one of the balance end stones and my replacement only came in today. So I’ll clean it, oil it and put it back in. Then I’ll demag and see how the amplitude responds.
Edited by neevo
Do you have any sort of meter to confirm the voltages.
Edit
If not can you confirm what it says on what I expect is a relay in the bottom left corner of the PCB.
Edited by AndyGSi
There are two big black capacitors on the circuit board in the picture posted by @neevo,  and the one at the back has markings for 220 nanoFarads at 630 volts.  I can't see the markings for the huge black capacitor on the right hand side of the case,  but I suspect it will be similar to the 4 microFarad one from @LittleWatchShop's circuit diagram.  With diodes in circuit, it could easily have 350 volts on it,  and judging by its size,  it would pack a hell of a punch.   I, personally,  wouldn't risk poking at it even with the mains power disconnected.  You definitely don't want to be fooling around with those sorts of voltages.
I think,  when I buy one of these demagnetisers, I might keep a plastic rod handy for pressing the button,  just in case.
I had a few more tools and parts come in recently and this morning I was able to put them to use.
Using my new titanium tweezers I set about oiling the new end stone for the chaton and putting it back on the balance. It took me about 20 goes to get the balance back in with the impulse jewel in the right way. I get the concept but just couldn’t execute it properly. Patience and taking it back out and trying again was the trick and there is something magical about it kicking in to gear on its own!
Heres where I think I’m running in to a new issue. I dont have a timegrapher. Instead I bought an app for my phone and trying to use an old pair of headphone. But I’m getting really erratic results on the app.
It’s showing the amplitude at 315 degrees and it’s clearly better visually on the balance. However the app is really struggling to lock on to the movement so I don’t really trust the readings yet.
For example the beat error is 4-5ms and the rate is all over the place.
Then I realised I forgot to demagnetise. So I popped it on my demagnetiser and retested.
Does the app take into consideration the lift angle as 315 is high.
I’m not sure. I think the main issue I’m having with the app is that it’s not really picking up a strong enough signal from the movement. Only 1 out of 5 bars lights up. Maybe the microphone on the headphone is not good enough to pick up the sound.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
