I'm interested what you guys are using for clock regulation.  I can do it the old-school way obviously, with manual adjustment on the bench.  With watches I use a timing machine to speed up the process.  Is there any equivalant method to use on clocks?  I'm aware of the Timetrax machines but they dont seem to be available.
I'm trialling the Clockmaster app now, will report back and share findings.
Edited by MikeEll
15 hours ago, watchweasol said:
the Timetrax is available through  Cousins UK.
If you keep an eye out on eBay because TimeTrax is been around for a long time with a variety of models they will show up. Otherwise there's the cousins link below.
https://www.cousinsuk.com/search?searchTerm=Timetrax
Another popular one is the Microset found at the link below. Then the second link is someone talking about using it.
When you're looking at the actual descriptions of the various Microset machines for clocks you also notice there's a reference to a book that comes with it the The Clockmaker’s Beat Book. Unlike watches that come in standard beats for the most part clocks could be just about anything so there are reference books like this that you look up your clock and ill tell you how many beats per whatever so you know what you're doing with your machine otherwise you'll have to do the math to figure it out. So basically a clock timing machine is not as simple as a watch timing machine but few know the beats per hour a have one of these makes regulation really fast.
https://www.bmumford.com/mset/
https://altrish.co.uk/2019/03/02/microset-clock-timing-instrument-upgrade/
Then I'm not a big fan of phone apps for timing but there are phone apps for clocks out there somewhere in the universe
One thing I forgot to mention. If you take the pendulum to pieces to clean or repair mark where the pendulum had been at least you will have a good starting point.
Yes, I do this already, good point.
Thanks guys.
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
