Bergeon 30207 How To Use?
bobm12
I'm thinking about buying this tool:
It is said it helps work on balances plus a lot of other uses. Can you guys illustrate/explain those different uses and if possible with support of pictures.
Much appreciated and thanks in advance,
Cheers,
Bob
I have looked at this tool many times. The idea is to secure hairspring stud while pinning a new hairspring to it I think.
However I think it would be very handy when manipulating a hairspring. The cost as always put me off
This tool might do the same job on the bay item number 311482941796
A strange tool to find pictures of because it goes by multiple of names. Plus to make things more interesting hairspring can also go by balance spring. Then for such an interesting tool not finding a lot of references to it?
http://www.geocities.ws/dushang2000/Balance%20Tools.html#Balance%20Spring%20Stud%20Table
Nice link John very informative
What's interesting is missing tools for removing the balance staff plus his staff grinding tool extremely expensive and if you're not careful bad things happen. Specifically if you're not careful you grind more than the staff and you make a nice hollow into the balance arm. Then if you are grinding out it's always good if you would measure which are grinding out just to make sure that whatever you replace with exactly matches.
Then as pointed out Missing is the Platax tool I've attached photos of something else that's missing.
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
