Front loader that won't come out.  Has a ring below the dial that moves a little but ends won't go past stem tube.  Looks like a special tool like snap ring pliers?  Anyone deal with this before?
the ring you talk about is a locking ring it's not supposed to move very much at all. It basically goes in one direction to lock and the other direction to unlock.
On the top your image I put marks that's where you would push in one direction or the other for locking and unlocking.
Then we need to see something that we can't see which is the metal tabs. I put the marks where you can see the openings which have to be in the right place for the tabs on the movement they come out. so if you're lucky you may be a look at with bright lighting as you push on the locking ring one direction or the other and I don't think it has to pass the stem you should be able to see the tabs underneath.
You should be able to turn the dial and movement  as JohnR725 said so you can see the two steel tabs it should then just come out turn it on its side.
  I have an Omeag just like your watch, used watch when I bought it, dial was warped .
 Just want to inform you , these dials warp real easy, hate to see your next image with warped dial.
Beautiful watch you have.
I turned the locking ring to line up the tabs and with some very carefully prying it popped out.  Thanks everyone.
now that it's out for future reference can you give us a picture of the case without the movement so everybody can see the locking ring.  then a picture of the back side of the movement so people can see the locking tabs on the movement themselves.
10 hours ago, Nucejoe said:
dial was warped
probably warped because somebody was trying to pry their movement out not recognizing that its locked in place with the ring.
the problem sometimes with photography and my reading skills are I'm not 100% sure what your case number is? In other words 62? Like maybe 6267 or 6287 which by the way both exist which would be a problem?
So you can go to this website
http://cgi.julesborel.com/
and in the search box enter it in what I have below
ome CS#62
you'll notice that I'm only doing a partial number is I didn't know the rest and that is helpful in that it gives us a nice big list so you have both numbers to pick from. When you click on the number you'll get a list of parts which will give you the crystal number
then somewhere out there will be generic crystals but with a case like this the crystal is key it really is important to have the right crystal in other words I would try to stay with the original mega crystal. You'll notice that the crystal itself as the inside ring that's the other problem with generic crystals it has to be shaped correctly. Then if you can only find a white crystalline other was a white metal ring you can take the ring out of this one providing it hasn't been damaged and swap with the other one so that gives you another option for a crystal
I believe  the case # is LL 6287-1.  Even with your excellent directions my lacking computer skills turned up nothing.  I definitely want an original. Inside ring is in great shape and is a split ring.  Would the Sternkreuz be an original?
Looks like the pz5072 would be an original but for $175 I would like confirmation before buying one.
9 hours ago, markr said:
Would the px5072 be with the gold ring?
Apologies, yes the PX5072 is Gold the PZ5072 is Silver or sometimes listed as without tension ring.
Edited by AndyGSi
Well new mainspring, crystal, and setting lever spring and she is near perfect.  Now I need a new split stem crown. Old one lost the washer that held the seal in and now everything is falling out.  Can anyone please help me out with a part number?
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
