I'd be grateful to know if there's a way of removing the stem of this mini (31mm dia) pocket watch without dismantling the keyless works. It bears the term "PONTENET" on the dial plate by the crystal hinge.
Oh and it does appear to be a cylinder escapement you want to pay attention to that to avoid unpleasantness things from happening. I rather enjoyed a YouTube channel who will remain nameless disassembling one of these and I was wondering if? Yes you can tell it's a cylinder because of what you see on this side. In the video I was wondering if he had let the power off and oh never mind he removes the balance wheel and escape wheel starts spinning which is an extremely bad thing to do. Yes the joys of watching YouTube watch repair where nothing bad ever really happens but it's a miracle that it does not.
We really do need a picture of the other side of the watch.
1 hour ago, JohnR725 said:
Oh and it does appear to be a cylinder escapement....
Thanks for the warning  - I'll need to look up "cylinder escapements" !
Here's a photo of the back of the movement
Normally you would loosen the screw a couple of turns. Don't remove it entirely.
Also, my thoughts (for what they're worth) are that if you're fairly new to watch repair (as I am), a cylinder escapement is probably not the best place to start. I haven't done one yet, and don't feel I'll be ready to for some time.
It seems to me that cylinder escapement watches are very common on eBay so its worth being able to spot them. If a pocket watch movement is offered for under about $50 and it is not missing parts or full of rust, 80% of the time it's a cylinder escapement. Things to look for include no maker's name or caliber number on the movement or dial--they were cheap watches in their day that nobody was especially proud to be associated with. The real give-away, though, is to count to pivots of the train of wheels. A Swiss Lever escapement will have Centre Wheel, Third Wheel, Fourth Wheel and Escape Wheel pivots visible on the movement side, and there will be some space between the Escape Wheel and the Balance where the Pallet goes. A Cylinder Escapement will have one less pivot visible as there is no Pallet and the Escape Wheel interfaces directly with the cylinder on the Balance staff. If you can see the Escape Wheel, it will also have a distinctive appearance with what looks like tiny hammer heads on the end of each tooth. They're the things I look for; if I've said anything egregiously wrong I trust a more experienced member will correct me.
Edited by GPrideaux
Additional information added
Thanks for taking an interest. As the old joke goes re giving travel directions "I wouldn't start from here if I were you !". This is a watch a friend has asked me to look a & see if there's anything I can do, not one that I've chosen.....
Hi it’s a Swiss  five bar. Cylinder movement.so named by the fact there are five bars or cocks each holding its own wheel etc. not a watch to take on lightly. The balance wheel has no roller but the staff is cut allowing the escapement to work , the staff pivots are plugs or tampons, can be replaced but needs special tools and a lot of experience.
Yup I saw that too. Five minutes of research before that disassembly wouldn't have killed him.
I thought I would give the link to the offending video which by the way is the second video. But six days ago he is doing it again and yes five minutes of research but does it matter? He has close to 1 million subscribers he makes happy videos on how easy watch repair is and he definitely does not do things right but apparently those things really don't matter. Memories making entertainment videos try not to pay attention them as actual service videos
then I can't say the cylinder is my favorite watch to work on at all. Very definitely always remove the power and be extremely cautious as breaking things on this watch will be very bad for you. In fact I would actually stay away from cylinder watches as their vintage they're not usually made in outstanding quality although? There are some outstanding quality cylinders including those that have rubies cylinders. I would also stay away from those they're well out of your price range if something breaks as there will be no parts for those and fixing anything on the cylinder watch getting parts is just a big pain in the ass.
okay now to the watch video that definitely do not follow his practices
Oh I was referring to the recent one, and I forgot this happened in the Breguet video too.
👍i buggered up the replacement of one of the tampons a few months ago. Attempting to reposition the good one that was set too low the cylinder cracked in half. I didn't swear though so at least I'm improving that aspect of failure 😅
  • Haha 3
Thank you. I've got it running but only dial down. Does this suggest anything differerent, in terms of next steps, than it wolud for a lever escapement ?
it would suggest more troubleshooting on your part. In other words why is it not running dial-up? That means you get stuck checking the pivot on that end and/or the jewels. usually because the age of these watches and not necessarily known as a stellar quality watch the jewels may be a poor condition. Plus of course classically anything that's vented somebody may have worked on it before you. So I can a watch you have to look at the pivot and everything related to it
Whel it is a cylindre. First of all, it is not enough to have it running with no stopping, but amplitude should be at least 90 degr to be sure that it runs confidently. After disassembling, put only the balance with both the cocks on the plate and do the free oscillations test. There should be no difference in both horizontal positions and at least 50 oscillations are expected. If this is not so, then pay attention to the pivots and bearings. As this is cylindre, the axial free play of the balance (if it is big) may cause the teeth of the cylindre wheel to go away from the correct trace on the cylindre mouth, so this is one of the important things to check. Lubrication of cylindre is important here to achieve good amplitude. My experience is tat the best results gives very small amount of moebius 8020 grease only on the trace where teeth make contact with the cylindre.
It is a lady's watch and they usually  wore them as a pendant on their necks.
Oh my heavens, @JohnR725 this fellow scared me a few times.  I happen to have a cylinder Breguet (which is either one of their more modest offerings or may be a souscription - it does not have a ruby cylinder, just a steel one like the above watch, but the construction is Breguet).  My movement is identical to this one, but the case is silver and not gold.  The difference? - I have serviced cylinder escapements before, and they do behave a little differently from levers.  It is also best to have the extra, needed tools - the special weird-looking punches that reach into the cylinder to push at the tampons, and the stumps to support the balance properly.  Watching this guy just jump in with both feet, without apparently reading a little bit about them so he'd know what he was getting into, that made me wince.  That poor watch.
There are several things that can cause a cylinder watch to misbehave or not run at all.  And many of them are the same issues that would also stop any other kind of watch: dirt, congealed oil, wear, damage caused by carelessness or accident, or damage caused by inept repair, etc.  But one thing that comes up is *inadequate* lubrication.  Each of the escape teeth needs just a tiny smear of oil.  It's a friction-rest escapement and one must mitigate some of that friction.  And it is best to service it yearly if you are going to carry it and run it throughout that year.  Friction and wear are much more of a bane to cylinder escapements then to any other kind.
Another problem with bar movements that have this kind of suspended, hanging mainspring barrel: misalignment.  I had to bush the hole in the bridge of my Breguet because wear had caused it to tilt and bind against the center wheel, and rub the underside of the hour wheel on the other side.  Once I got it back at proper height and alignment it ran very well.
Seeing that video reminded me; I started out a little ahead of this fellow.  I'd already read quite a bit about cylinder escapements and how they worked before I was confident enough to work on one.  I was prepared for the surprises.  The poor man in the video was not.  Clearly the movement did things that surprised him.  Surprises can be a bad thing in watch repair.  I am holding out hope that this experience does not discourage the man in the video from learning better practices with regards to cylinder watches.  His videos are very watchable, and I'd like them to improve.
His videos are extremely valuable for promoting the hobby of watch repair. As he makes watch repair look fun for all.
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
