I have read previously that you should never use IPA to clean acrylic crystals and I filed that knowledge internally, to avoid it.
While pre-cleaning some movement parts with IPA, I managed to get a healthy splash of it on clear part of a cheap mainspring barrel press. I wiped it off quickly and didn't think any more about it. About 10 minutes later I picked it up to put it away and there was a massive crack running right across its diameter and down the sides. When prodded it cleanly split into two halves.
Lesson: be cautious as to where the IPA ends up. You might think it is one of the more benign chemicals that we may use but it can obviously do damage.
I would see acetone being a problem but IPA, not so sure. That looks more like a stress fracture, chemical incompatibility I would expect “melting “ of the material rather than this.
Tom
Tom
May have had an unnoticed fracture/ flaw in its structure waiting to be further stressed. Glass has manufacturing flaws that can suddenly rupture with temperature random stress changes. Toughened glass can do it spectacularly for no apparent reason.
No reason i can think of to use any solvent when restoring an acrylic crystal when diminishing grades of wet and dry and a final polishing paste makes a good job. Maybe a good reminder to safely store away the crystal when ipa is being used.
We were taught in dental school that alcohol can cause crazing of the acrylic used for dentures. But I've never seen a crazed denture in my 38 years of practice. Crazed patients... yes.
From my own personal experience, I once cleaned the acrylic lens of an LED torch with IPA and almost immediately a crack line started to form.
I know for a fact that using "Locktite" on any screws or nuts in contact with acrylic causes the plastic to start cracking in that area. I've seem it on machines that have acrylic door windows & guarding.
There are definitely some solvents that affect it, though I've never noticed anything with IPA; it possibly depends on how long it's on contact?
As an experiment I once tried 99% IPA on an old acrylic crystal. It first went cloudy, then cracks developed.
I assume that all optical lenses are not any form of acrylic, as don't lens wipes contain IPA ?
How long did it take until it went cloudy and cracked?
interesting, as I tend to give a mucky acrylic crystal a splash of IPA and wipe off to clean it. i've never had one crack or go weird on me.
Medical and research apparatus is often fabricated from thick sheet acrylic, and since there is usually a spray bottle of one type of alcohol or another on most lab benches, inadvertent damage often occurs.  Woe be to the undergraduate helper that compromises an expensive piece of equipment by innocently wiping it down! I've even seen "No alcohol" decals on newly-purchased items as a reminder from the manufacturer.
Product info often states that concentrations below 30% are moderately compatible and can be used for brief cleaning exposures, but most people stock concentrations above 60% on the bench because that is where you need to be for disinfecting activity as a surface treatment.
I think I left it for several minutes.  Like you, I will still give a swift wipe of an acrylic with a splash of IPA.
One night, we were bringing a pot of water to boil on our cooktop and the tempered glass portion of our vent hood shattered rather spectacularly.  Threw glass shards up to 20 ft away. Dinner was ruined and we had quite a mess to clean up.  Luckily none of us were at cooktop at the time.
I am rather surprised that IPA would have that affect on acrylic.
Couldn't say regarding acrylic but if has an external flaw somewhere that is affected and the piece has internal stressed going on then i suppose its structure could be compromised.  Toughened glass is renowned for this, i once remember picking up a double glazed unit , grabbed each side  it shattered and left 2 imprints of missing glass were my hands were. The explosion can send glass hurtling everywhere, fortunately the pieces are too small to cause serious wounding but they can still cut and the glass dust can be a problem.
I can't find any information in why IPA could shatter acrylic.  Crazing is caused by the top layer being dissolved and resetting at a non uniform rate.  I can only take an educated guess that the acrylic was already stressed.
Almost certainly it would have been because the part was under stress to begin with. It looks like it is machined from a solid piece and it is ultimately used for pressing components together. The IPA would have just have worked on the stresses already present.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
