25 minutes ago, LittleWatchShop said:
I don't see any other mistakes.
Should I add this capacitor also?  I didn't think I needed it.  It wasn't on the original schematic, I had added it because the data sheet for the rail splitter showed it....
35 minutes ago, LittleWatchShop said:
You never fixed this issue and I missed on subsequent reviews
I followed the schematic below....  Supposedly he got it working like this....  It is a LT1115 and he is using it as a buffer not amplifying with it.  The rest of the OP amps are 5534s.  This schematic is from a previous post several pages back...  It is a modified version of the watchOscope one.  (Which I did make last week)  I am making several difference ones to see what works best.  I am using a modified microset as a preamp right now in my diy setup which works quite well.
1 is not equal to 2.  Go back and carefully look at the datasheets for these parts and look at your schematic.
There is a major error in the schematic, it will never work this way ? :
negative supply pins are connected to +4.5 V and +inputs of NE5534 are connected to 0 V!!
Another question, to what input are you planning to connect your preamp? Will it bear an output signal of 0.75 to 75 V_peak (theoretical - there will be clipping of course)? For what do you need that ambitious amplification of 7500x ?
Frank
Frank
Thank you...  Please tell me how to fix.  Looks like I have 9v at neg supply.  image.png.2c4a6a55c87f28bcf242ae7de0461a6a.png
UpdatedOpAmp.TSC
In fact you have. I wonder if you already blew your ICs?
You should connect:
+9V to V+ pins
0V to V- pins
4.5V (TLE2426) to +In pins.
...and think about my 2nd question.
Frank
Edited by praezis
  • Similar Content
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
