Half of a Two for a Dollar Deal
Hello!
I'm Jay, a new member!
I have a love for mechanical watches and clocks, to the point that I'm all out of wall space and I'm in the process of expanding my watch storage
I was at an estate sale and there were two watches, tightly packed into a plastic bag. I couldn't make out what was inside, but when I saw the $1.00 price tag I decided that my curiosity could wait until I got home.
Inside I was rewarded with a very early Enicar and this Timex. I cant find any numbers that will help me with date and model, so I thought I would seek outside assistance. Look familiar?
Thanks!
Jay
5 hours ago, HectorLooi said:
Out of curiosity, I checked what $15.95 in 1960 would be in today's dollars.
and for the calculation, they most likely used the governments CPI index. So, in today's confetti currency, the price would be even higher 😆
    • Are you all jerking my chain, I'm a yorkshireman £4.04 is too much 😆
    • [Myota2034] Custom simple quartz watch — PricewaterhouseCoopers On a very very different note, here is a watch from approximately 2000 when I was a Partner with PwC, Management Consulting. It was a simple “marketing watch” with a clever “vase of knowledge” that is subtly revealed on the dial as the second hand progresses. Clever for a simple watch!⌚️
    • I think someone else has though. Some where here using a modified perspex sheet. I may be wrong i may be right , i think it involved fitting the arbor to a pin vice. I dont have experience of the bergeon winders, are the handles not interchangeable ?
    • Never tried dial dots, i always considered them as a bit of a bodge.  You are adding something that was never intended to be there. I wonder how the adhesive reacts to any part of the movement, hot summer heat and i think things might turn sticky. Most adhesive backed stuff has a tendency to soften and slide around so it may spread, i have used a lot of so called sticks all adhesives in my industry that are just not up to the job. I suppose they get you out of a problem quickly, but how permanently might that be ? I would just explain to the owner that it may or may not work. WWs other ideas are a much more permanent solution but both have their risks . I've tried milling and dial feet replacements, hmm it was ok, ive heard of folk dimpling the face , so that needs care . And i have soldered a few times , all with good results but i am very careful and I practiced it a lot.
    • Thanks very much watchweasol. A couple more dummy questions. What do you mean by 'cut block'? and to see if there is pulse on the chip, which contacts on the chip should I connect the multimeter? Many thanks
