Hi guys,
I wrote this lesson for my second students to understand the theoretical aspects of the Swiss lever escapement in conjunction with the practical application of end-shake and setting jewels using a jewelling tool. Both Seitz and Horia-type jewelling tools were used. Although I talk about measurements using the settings on the side of the jewelling tools, it is more about what 'feels' right, especailly when gauging the end-shake of a particular component, such as the balance, pallet and escape wheel.
Ideally, you wouldn't start by adjusting the end shake of the balance to suit your needs, but if the IncaBloc setting has been replaced or the Inca setting has been moved to replace the shockproof spring, then it is important to set the end-shake correctly. This presentation also looks at how to set the correct end-shake of the pallet in relation to the balance safety roller as well as other critical measurements, including the height of the escape wheel teeth hitting the impulse face of the pallet fork in both dial-up and dial down positions. The escape wheel and pallet have to have the exact same end-shake as each other for this reason.
Unfortunately, the slides that contain videos can't be played as I converted the PowerPoint into PDF.
I have used some diagrams from a WOSTEP handout on this subject, to show the vital measurement of the escapement in relation to the balance safety roller, so all credit goes to the author of that hand-out, which has been posted several times on this forum.
All the students that set all the jewels after removing them and the balance end-shake to its optimum got a watch movement working with much improved amplitude than when they started.
All ten jewels in the wheel train were removed as well as both IncaBloc settings. Another lesson was created just about the balance setting and disassembly and assembly of the EtaChron balance system which included removing a replacing that Inca setting. I haven't included that lesson.
Not every aspect of this work is within the presentation, as it would be very long otherwise. I talk a lot and explain more as the lesson proceeds. This lesson was held over six to seven hours.
If anyone is interested in learning more on this subject, please message me.
Lesson 16. Balance endshake & Incabloc adjustment.pdf
Edited by Jon
updated info
  • Thanks 13
3 hours ago, Jon said:
Hi guys,
Not evry aspect of this work is within the presentation, as it would be very long otherwise. I talk a lot and explain more as the lesson proceeds. This lesson was held over six to seven hours.
Really great lessons John. Goldilocks ? and the three bears ?
Many thanks for sharing it is a great topic and concise explanation full of clear pictures. Many hours behind that ppt for sure.
I was wondering if you have other ppt or info on how to fix a new lire (incabloc spring) I am still struggling with that task to the point that every time I am about to oil the jewel cap I put a little bit of rodico on the hinge to ensure it won't come out. I am referring to the one on the main plate...
Thanks, Fernando
If I'm understanding you, you said how to fit a new lyre spring. To fit a new incabloc lyre spring, it is in slide 16 of the presentation. press out the Inca setting enough so the 'T' part of the spring can fit in the slot of the Incabloc setting, then press it back into place with a jewelling tool.
If you mean how to attach the lyre spring arms over the cap jewel, let me know and I'll post something
Many thanks! I use the term 'Goldilocks' a lot in my lessons. And yes, there are always three bears. I call them Peter, Paul and Jill.
In watchmaking, especially stuff involving the escapement I tell my students, "If you're going to rob Peter, then Paul is somewhere in the shadows with a baseball bat wanting paying and just when you think you've paid him off, Jill comes out from behind Paul with a flick knife because you fell into the trap of making an assumption. If you're gonna rob Peter, you have to pay Paul, so if you adjust the endshake of the pallet jewel , you have to take into account the height of the guard pin with the safety roller and Jill is the escape wheel hitting the top half to three quarters of the impulse face of the pallet jewel. Peter, Paul and Jill, I love those three! 🤪
Edited by Jon
Yes, my question was about fitting a new lyre spring. By the way, it was my bad that I did not notice you mentioned how to do it on page 16. Many thanks for your patience and time, best regards
Jon.
I notice that you have given lesson 16. Obviously there are more. Are they available?
Hope so. Really interesting and informative. I was actually able to understand and follow. I do have the tools available (Chinese set). Although I have not yet worked at that level. I can see the way forward to attempt such.
Staking set no longer holds a fear. So, onto the the next level.
On your site, You have a curriculum for for learning by attendance. Obviously I live too far away. Can I Purchase the lessons for home instruction as a distance learning course.?
Thank you.
Edited by rossjackson01
57 minutes ago, praezis said:
Here the increment is 0.02 not 0.01 mm
somebody a while back was asking me about this and the 0.02 is basically the standard which everyone has but if you look at the links below the first one is 0.01 so they do exist. I don't know visually if you can tell what the difference is other than by seeing how many turns it takes to go up and down
https://www.horia.ch/en/Products/Jewellling-Setting-staking-tools/Jewelling-tools/Jewelling-tool-pas-fin-spindle-hole-3-00-mm.html
https://www.horia.ch/en/Products/Jewellling-Setting-staking-tools/Jewelling-tools/Jewelling-tool-spindle-hole-3-00-mm.html
then minor nitpicky on my part but who makes this tool?
Very useful info.
But if I saw these numbers, I wouldn't be thinking "too little end-shake" (I would have checked it)
BTW, the way I visualise the correct end shake, is to imagine it about the same as the pivot thickness - about 0.09mm, which agrees with your slide.
Edited by mikepilk
On the jewelling tools I use they are 0.01 increments, but appreciate pointing out that it may be 0.02 mm in other tools.
I think whatever tool a watchmaker uses, they know what the measurements are before starting to use it
Hi @Jon, in the picture in question there are five divisions between the 10 (0.1mm) and 20 (0.2mm) markers, so surely they are 0.02mm increments?
Well spotted. The increments on the Seitz jewelling tool are 0.01mm and 0.02mm on the Horia. More and more I have switched to using my Seitz tool since I learned that it can be used in the same way as the Horia.
Absolutely, and it's certainly not a big deal!
You're right, Well spotted! I used the wrong tool in the slide, so I've now corrected the slide to reflect each increment is 0.02 mm on that particular Horia style tool. Many thanks for that.
To err is human.
Edited by Jon
Not really. I remember being confused by this and using a wrong adjustment. Probably because I use both, Seitz and Horia.
Frank
@Jon
The PDF in the first post is no longer available. I downloaded it earlier today but future readers will likely be disappointed. Perhaps you can try to upload it again!? Thanks!
Too bad PowerPoints can't be uploaded. If it's OK with you I'll PM you my email address. You can then send me the PowerPoint (hope it's not too large) and I'll place it on my OneDrive and share the link in this thread.
I also saw that video 1-2 months ago and was delighted! I only had/have the Seitz. It works perfectly well with the turning knob. And yes, nice to see the 0.01 increments.
It only works with the newer versions of the Seitz jewelling tool, not the older ones
I've reposted the original PDF file, as the original one became unavailable when I edited it, so sorry about that.
If you want the PowerPoint presentation with videos, here's the link to my cloud storage, but it won't be there forever. You will need a newer version of Microsoft Office to play the videos, otherwise they won't play
https://docs.google.com/presentation/d/15lXEoRsUF_xKhRB0XaoMU566s7LB279V/edit?usp=sharing&ouid=107902587627140904870&rtpof=true&sd=true
  • Thanks 2
Thanks, Jon! The video sequences really add to the content and the understanding of it, so many thanks! 😀👍
Here is a link to the same PowerPoint on my OneDrive. It will probably sit there until I stop breathing, but let me know if you don't want me to share it.
Lesson 16. Balance endshake & Incabloc adjustment.pptx
That's valuable information for those on the lookout for their first Seitz jewelling tool! 👍
Jon and VWatchie Thank you for the video facility in the PowerPoint. Very informative when you see the 'live' version of the written word. Helps beyond belief. Not tried to replace a jewel or setting yet.  However, seeing the process adds to the overall learning.
For reference I believe this is the older style, absent are the inside threads for the cap that allows for horia-type pushingIMG_0851.thumb.jpeg.21770341f8ce304f5fb331b41b81aed5.jpeg
I guess I got lucky then! It didn't know about this when I bought mine.
But even if you get the newer version, you need to make sure the respective adapter/knob is included.
See pictures below.
20240303_133041.thumb.jpg.952dc2f7ccfda6519460175425cff16d.jpg20240303_133047.thumb.jpg.4683ba2ec0a3496645f5d6694a6ac903.jpg20240303_133127.thumb.jpg.1aa0c6c5f400775ce0e732761d846e0d.jpg20240303_133114.thumb.jpg.05ea47ef0e2cf738c31d7d6842e8c2b3.jpg20240303_133101.thumb.jpg.5cca8bd7f825182317e7c9a993c6ebed.jpg
  • Like 5
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
