Click spring replacement
Pieter
How do you replace the right click spring in a Smith’s Enfield railway clock? How do you attach it to the front plate? With a rivet and a hammer or bolt? Not much room behind the plate for there is the clock spring. Any video link?
13 hours ago, Pieter said:
I drilled the rivet out. How does the screw get enough grip? The plate is very thin….
The click spring should have a tiny notch that fits into a small hole in the plate. Just a tight screw down will be fine or to be safe a spring washer. (If room)
Hi Pieter, I have purchased these rivets from a company called Accu - heres a link https://www.accu.co.uk/ the rivet I used  is 2mm x 6mm Button Head Solid Rivets (DIN 660) - Stainless Steel (A2)
You can buy the springs from lots of sellers online but I have found some sizes are very hard to come by. They are either Left or Right and the critical thing is the distance between the screw hole and the tag that engages with the hole in the plate. I ended up buying a straight spring and bending it to the required size.  I bought mine from this seller on eBay
eBay - Advanced Search - Shops - Find Shops - Lisa's Pet and Home Store
I can understand why you would prefer to use a rivet but to be honest I found it impossible to splay the rivet enough without breaking the spring, so I gave up and used a self tapping screw which has worked really well.
Good luck !
Edited by Michael20
Good luck !
Thank you for the advise. The frontplate is so thin so i am wondering if a self tapping screw will hold but i will give it a try. Do you know by the way hiw to adjust the hour hand on the fusee clock? Is is a little bit off so i like to adjust it.
Normally the hour hand on a fusee clock is friction tight. When you have the minute hand pinned on hold the minute hand near the center then try to move the hour hand by holding it as near to the center and move it to the place you need it to be. Always move hands from the center this prevents bending the hand and breaking off.
    • Hi other than testing the coil without the proper tools it will be difficult.  If you +an rig up an external supply and attach it to the cut block you may be able to pick up the pulses on the chip if not on the coil. i have attached the parts sheet for the watch 9362 which gives you the part number of the cut board assembly, whether this part is still available or not , who knows. ETA 9360, 9361, 9362.pdf
    • Hi and welcome. First of all, check the power reserve. If the watch is runing, this means the spring is attached to the barrel arbor. If there is no end of winding, this probably means that the spring is not attached to the barreland it's outer end is slipping. In such case, the watch will run, but the power reserve will be small - about several hours
    • Hi welcome to the forum. One can only reiterate the diagnosis already made by clockboy mainspring problem. But before tearing it to pieces take a little time to read the attached file to acquaint yourself with all the various parts. TZIllustratedGlossary.pdf
    • We think about these preps as "one-dips" partly because they are terrific solvents but also because the parts they are used on are often cleaner in general than many other parts. But old oils petrify, and even something like B-Dip can't clean up over-soiled parts without some extra effort, as mentioned above. There is an intermediate step during cleaning where the solvent can partially dissolve tarry residues so they have a more liquid varnish-like consistency, and that could well be what you are seeing on the coils after two washes. I wouldn't worry that your B-Dip was contaminated before you used it on this hairspring, but it I wouldn't re-use that aliquot AFTER this cleaning!
    • Welcome to the forum, enjoy.. Normally if a hand wound watch does not fully wind ie just keeps winding there is an error with mainspring, either slipping around its winding arbour or the mainspring is broken.
