Is this pivot broken
Hi all, I fell stupid for even asking this but does anyone think the top pivot is broken (the hairspring side). my eyes cannot quite make it out even with this magnification,  I serviced this watch 2 years ago and it has just come back to me , the owner said very rarely wore it just been sitting in a drawer takes it out a few times a year to wind it. last time he took it out it had stopped working. It was fully wound when returned to me and as soon as i slackened of the balance cock screw it started running, re tighten it stopped. literally half turn of the scvrew would start it running and in dial down position on the timegrapher it ran perfectly dial up terrible -897 and like it was magnetized so I assumed a broken or damaged pivot or dirt etc, when i took the balance off the cock as shown in the pics the first thing I see is a tiny piece of metal stuck to the underside prob 0.1 mm in length which I took to be the tip of the pivot but looking at the staff under the microscope I am not sure, what does anyone think. the watch is a vintage 1930s gruen curvex cal 440.
no that little bit of metal was stuck to the underside of the balance cock hence i assumed a broken pivot, you have confirmed what i really thought so i an thinking just dirt or congealed oil, the balance pivot was black on the end and i have now cleaned it and polishes it a bit, i have stripped the cock and cleaned the jewel and cap so will put back together and hope this solves the problem. thanks for the input.
no it still did not run properly even with the balance stripped and cleaned. It ran very slow on the amplitude almost stopping . I have now completely stripped it and cleaned it  and will start from scratch. I did notice that the mainspring seemed to be partly set so I have ordered a new one with my thinking being that the spring was not putting out enough power to move the balance as also if I touched the centre wheel it started the balance running properly. Fingers crossed that will be the answer.
One of the things that helps on these discussions is a name like we have above sometimes a picture is nice to see what were talking about
http://www.gruenwristwatches.com/440-movement.php
So we have a interesting background history. Also it's always nice if you show us the timing machine results so we can see what it actually looks like it helps for us trying to diagnose.
When you service the watch the first time did you change the mainspring? Because one of the problems with especially original spring is the blue steel ones they definitely have a habit of setting. Then unfortunately vintage old new stock mainsprings also have a habit of setting. With the added bonus now that the quality of some modern Springs isn't much better than the original Springs.
yes it was an vintage new old stock blue steel spring that I had in my stock, the new one that I have ordered from cousins appears to be a new one which as i type this has just turned up, also interestingly the size given on the Gruen website for the spring is different from the one in the GR catalogue (Gr2631 H 1.10 x T 0.11 x L 240 BD 8.5). I take your point about pictures I will endeavor to include them in future posts.
definitely set.
well the spring did not work, balance was still the same running intermittently and has now stopped altogether. Having a good look it is possible looks like the balance spring is slightly bent and is rubbing on the balance arm. Anyone know where I can get a new balance from for a 440 or 335 cal.
best i can do pic wise
    • A couple of pictures of the front… Sorry, I’m months away from this one, but…there is an edge to the bezel but I see no obvious signs of previous bezel removal and it is quite thick so it would be difficult to grab an edge on the crystal with a crystal lift. It does look like in/out thru the back…good luck…
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
