I have been working on a 1960s/70s Elliott dual chime mantel clock. The case was poor but the movement seemed OK. I took it apart and cleaned all the wheels and the pivot holes (which were in good condition). It has a platform escapement which I did nothing to because it looked alright. When I reassembled it, the clock ran for a few hours then stopped. It got going again when I moved the hands but the most it has run for is about a day. I have taken it apart again to check I didn't bend a pivot by mistake but they look okay. Could it be the platform escapement? Not sure how to go about cleaning it and where to oil it. Does anyone have any advice?
Have attached photos of the platform if that helps.20240205_214805.thumb.jpg.22e928cdb2a9288c35b03a904c5becee.jpg20240205_214816.thumb.jpg.697062337bf333aa86f7d1a9a30c8802.jpg20240205_214845.thumb.jpg.f04a050031d731f6164d6f8a6a6d9c4b.jpg20240205_214905.thumb.jpg.a04ed16cebe8c79ec60d70a674dcba46.jpg20240205_214942.thumb.jpg.365bbae3d5cc41e7efd00621ad4a0f87.jpg
It sounds like the contrite wheel is not at the correct depth to the escape wheel. Make sure the teeth on the contrite wheel are good and make sure it has hardly any end shake. Cleaning and oiling the platform is needed, The screws that hold the platform to the movement gives you opportunity to also adjust depth.
Thanks for the advice and the instruction guide. To clean the platform will I need to get one-dip? Do I follow all the instructions about removing and cleaning jewels? For oiling, I have some Moebus pocket watch oil and a fine oiler. Do I oil the escape wheel teeth or the pallet jewels? Having never done this, I am a bit apprehensive about taking it apart.
If you don't have a watch cleaning machine. Clean all the parts with Ronsonol lighter fluid, after cleaning put the parts on some tissue and use your watch blower to dry the parts. If jewel caps can be removed then do so. Pocket watch oil fill be fine. Oil the pallet jewels and every other tooth on the escape wheel but do not over oil.
Rixy Elliott also fitted platforms that run silent just in case you don't like hearing clocks tick. Here is a photo of such a type, note the thick like hairspring fitted onto the escape wheel the escape wheel is different as well. My self I have some Elliott clocks 5 timepieces and 2 Westminster/ Whittington  chimes all with platforms
Edited by oldhippy
All I know is it works. I have a timepiece with it and it is silent, apart from seeing the hands move you wouldn't think it was working, the trouble is I forget to wind the thing up.
Thanks for your encouragement. I went for it. Reassembly was a tense moment but it's all together now and has been ticking since first wind and for over an hour - fingers crossed! This one isn't silent but very quiet.
The picture doesn't really show anything other than it being back together but thought I'd share it.20240207_214720.thumb.jpg.7c93322737d79267a372fffb7252f0af.jpg
These clocks are high quality, first class design and easy to work on. The only weakness I have found is with some platforms in the real older types they are not fully jeweled and you get wear in the pivot hole of the escape wheel. The really old Elliott movements are very dark in colour.
Good job Rixy. 😀
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
