The Seiko I'm working on appears to have two center wheels.  The 2nd wheel closer to the main plate and the 4th wheel on top of it. So are the shafts of both of these going through the main plate  (I don't see how) or just the 4th wheel?  Second question, there are 3 hands attached to the cannon pinion and shaft inside it But to work they must have 3 different sources providing rotational movement.  I believe the 4th wheel shaft is what the seconds hand is fitted over the end of.  One of the other hands could be fitted over the cannon pinion (which one?).  But what is the 3rd hand residing on?  TIA.
Here's a video of a 7s26 being disassembled.  At  8:50 you can see him removing the 4th wheel which is clearly centered over the 2nd wheel.
The Watch Repair Channel
Here is the disassembly of a Seiko NH36.  Pretty much the same. At 12:15.
Macro Time
I suspect, from trying to see, that the 2nd wheel, although centered, doesn't extend through the main plate.  It's pinion gear (between it and the 4th wheel) merely drives the 3rd wheel and the 3rd wheel's pinion gear drives the 4th wheel.
Here is a Seiko 6r15 being assembled.  At 24:45 he is lowering a bridge onto the 2nd wheel.  You can see the jeweled pivot hole for the 4th wheel being placed over the center of the 2nd wheel.
Macro Time
And here is a Seiko 6309A being disassembled.  Same thing, the 4th wheel is centered over the 2nd wheel and it's shaft is what is turning the seconds hand (I think).  At 8:03.
My Retro Watches
And once more.  Here's a Seiko 7009 disassembly.  At 20:18 he removes the 4th wheel from its position over the center of the 2nd wheel.  It's apparent this arrangement has been used by Seiko for quite a while.
Dumas Watch Repair
Dumas Watch Repair
And finally a 1972 Seiko 6105 predecessor of the 6309.  At 16:23.
Blair Witch Project
Technically, maybe. I suppose how you want to adhere to accepted terminology or semantics. Sure, you have two wheels on the train side that pass through the center of the main plate, so you could say both the fourth and the second wheels are "center" wheels. You could also call them "intermediate" wheels since they are between the escape and barrel. The forth wheel is the pivot for the second hand and is directly connected to the train. You set it by stopping the train (hack), while the minute hand is connected to the cannon pinion which is friction fit to the second wheel. This has to move independently from the train when the keyless works is engaged so hands can be set.
Edited by eccentric59
5 hours ago, RobBrandywine said:
Thanks, so how is the hour hand connected to the cannon pinion?  It can't be attached to the same section as the minute hand because it rotates at a different speed.
The hour hand goes onto the hour wheel which sits over the cannon pinion on the dial/motion works side. This is driven by an intermediate wheel and the minute wheel by the cannon pinion.
Tom
To clarify, the barrel drives the center pinion, which extends through the mainplate and carries the cannon pinion, The center wheel drives the 3rd pinion, the third wheel drives the 4th pinion, and the 4th wheel drives the escape pinion.
The center pinion does indeed extend through the mainplate and carries the cannon pinion. The long pivot on the 4th pinion, which is part of the 4th wheel, extends all the way through the center pinion, to carry the seconds hand. And as Kalang's excellent drawing shows, the hour wheel rides on the cannon pinion, driven from the cannon pinion through the minute wheel to get the 12:1 reduction necessary.
So the hour hand fits onto that pipe on the hour wheel?  That must mean that it (the pipe) fits on the outside of the cannon pinion?  Is it just above the bottom gear on the cannon pinion and below the bulge?  And so the minute hand fits directly on the cannon pinion above the bulge?
Now that I know what to look for I can see plainly in The Watch Repair video I linked to above at 29:27 the hour wheel with its pipe being slid onto the cannon pinion with some space above the pipe for the minute hand to go on.
Halleluyah!!!
If You had the watch dissassembled, You could answer by youself, with no others help, and this is much sweeter
And the minute wheel is a 12:1 reduction gear so the cannon pinion which turns once per hour gives power to the minute wheel, which in turn powers the hour wheel so it turns once every 12 hours. Very simple
I've got the watch, a Seiko 5 with a 7s26C movement, partially disassembled -- baby steps. The problem is that the watch stops at night during the day change unless it has a good wind  At first I thought it was going to be bent or broken teeth on the plastic wheels involved in day/date change, but they all look good. So then I thought maybe I had a weak mainspring and have one on order. But in the meantime I saw a video saying this can happen if the tension of the cannon pinion against the 2nd wheel shaft is too loose or too tight -- I forget which. Probably too loose.
Just remember, while this is a good understanding of the connections between the train and the motion works, it is by no means universal or absolute. You will encounter many movements with variations on this, or completely different designs.
That wouldn't be a loose canon pinion. A loose canon pinion wouldn't stop the watch, it just wouldn't advance the date. A weak mainspring or binding in the calendar works would be my guess. Pictures would help.
See, understanding is needed, not blind following what they do in videos.
If the cannon pinion is loose, the watch will not stop, but the hands will. The seconds hannd will run, but the minute and hour hand will stop. Is it the case?
If the spring is weak, then the amplitude will be to lo and timekeeping bad. The spring is not likely to be that weak, but it is possible that it is not wound enough by the autowinding or the outer end slips and thus the spring unwinds. In such case, the power reserve will be to small. Is it the case?
The problem can be in calendare itself. To check the watch without calendare, take out the day wheel and if the watch will start to work correctly (without calendare function), this is the case...
All good tips.  When it is partly back together I'll do those things.  I do know that if I wound the watch by turning the crown wheel directly that it would run for the full 42 or so hours. I also believe the seconds hand was stopped each morning.
Edited by RobBrandywine
    • ive got a 3220 dd module here that i go back to every now and then an it never works correctly , massive pain as i love the watch i that needs it!
    • I'm a little confused here before servicing everything was fine and now it's not? Then I'm assuming if you run it without the chronograph modular runs just fine or does it give you problems then? Then as far as tightening goes I've occasionally seen people use a staking set and sometimes it works sometimes it doesn't. You can also disassemble and flip it over that sometimes works. Otherwise try eBay and maybe one will come up. There is a tiny possibility if the Problem is on the gear part and not on the center tube that you could purchase a shorter version and pop it on your longer version that's a speculation on my part that may be that might work but if the tube itself is worn then you're going to have a problem then it's back to eBay and just try to find one in the first place all sorts of things will show up on eBay sooner or later.
    • Why do you need a whole balance assembly (balance complete)? Staffs are readily available and cheap.
    • Hi welcome to the forum. Enjoy. dictionary_ebauches_sa.pdf TZIllustratedGlossary.pdf
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
