Worn out barrel cap
I'm currently working on this Russian alarm clock.
The barrel arbor wasn't well polished and it caused a lot of wear. The barrel cap hole is so worn that the barrel is able to tilt enough to rub the bottom plate.
Is it possible to rebush a barrel cap or is it necessary to fabricate a new cap? The brass is only 0.8mm thick. Is that thick enough to retain a bush? Can I solder the bush into the cap?
2 hours ago, oldhippy said:
If the cap is thick enough to take a bush, bush it.
Thanks, OH.
I will rebush it first. If that fails then I'll solder the bush in. And if that fails, then I'll fabricate a new cap.
On 10/29/2023 at 1:41 AM, HectorLooi said:
Hi @nevenbekriev, in your article on setting pallet depth in The watch Forum, you mentioned Slava alarm clock as a good example to study the escapement due to its size. May I know what model is recommended? Would the model in the picture below be suitable?
Hi Hector,
I see now You have got one of this clocks. It is about 60 years old and made before II Moscow Watch Factory adopt the brand SLAVA. This is the first modification of this movements.
You have done perfect looking job on the barrel lid. Hope that the bush will stay in it's place, if it tends to foll off, then You can solder it. The way to solder it is to enlarge a little the hole on the lid first, so the bush will go in almost free. If tight fit, then the solder will not be able to penetrate in between. Does the barrel rotate true on the arbour now? The most important when placing such bushes is not to loose the center of the hole.
8 hours ago, nevenbekriev said:
Hi Hector,
Edited by oldhippy
2 hours ago, nevenbekriev said:
Sorry if I have done something wrong, but I don't understand what is wrong. Hector asked me before about this kind of clocks and now I see He has got one, (with the same movement), that is this thread about
nevenbekriev, please except my apologies, I didn't realize it was the same type of clock. I have removed it.
I originally put the barrel cap in a step chuck and enlarged the hole to receive the bush. So the hole should have been centered to the barrel cap. But the barrel wobbled terribly when it put it back in the movement.
So, I cut out the bush I put in last night and put in another one. But this time I fitted the cap back into the barrel, then I trued it up in my 4 jaw chuck and finished the hole receive the arbor. It runs true now.
I checked my step chuck just now and I think that it was the problem. For some reason, the step chuck doesn't run true.
Looks like I've got to chuck the chuck. 🤣
Often (usually?) step chucks are soft enough to turn. They have a through-hole of a given diameter, chuck on a piece of bar there, then you can retouch the step/s. Make sure there aren't any bumps or burrs on the cylindrical and tapered portion that fit in the lathe first!
If the bushing needs to be flush on the inside, I like to cut a small step (can be very small, like 0.2mm deep and bigger on diameter), and make the bushing with a corresponding lip, so when all pressed together it's almost impossible for the bushing to accidentally push out.
Edited by nickelsilver
Specially when barrel lid to be rebushed, I make the bush with smaller internal diameter. Then, put the lid in place on the barrel correctly according position mark, if thhere is no position mark - then make one. Next I turn a step on the face of a bar to enter the barrel hole and then fix the barrel on the face of the bar with shellac. Then I turn the internal diameter of the bush to size. This guarantees perfect true barrel rotation on the arbor
Hi Neven,
Thank you for the history of this clock. There was a "2017" molded into the bakelite base of the clock. I thought it was the production date.
The lume on the hands of this clock were replaced with black paint but I see from photos on eBay that the hands were originally lumed. I was thinking of restoring it back to the original look.
Do you think that the original lume had radium?
The natural lume is seen on the dial and it has green color. It doesn't seem to have radium, also they stopped using radium in the 50's and this clock is made later. Do the dots on the dial still shine for some time in the dark right after ehposed to bright light?
Good work with the hands!
The factory existed untill mid 90's and then was closed. In the 80's they started to put plastic wheels under dial and plastic barrel for the alarm spring. When the factory was closed, the movement looked like this and only 2 jewejs left from 11 in the original
IMG_22191.thumb.jpg.c7789e46cea4e42cdcf65105f19a1feb.jpgIMG_2221.thumb.jpg.ec05510efb865148014fd6e7cd419139.jpg
Edited by nevenbekriev
    • A couple of pictures of the front… Sorry, I’m months away from this one, but…there is an edge to the bezel but I see no obvious signs of previous bezel removal and it is quite thick so it would be difficult to grab an edge on the crystal with a crystal lift. It does look like in/out thru the back…good luck…
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
