Worn out barrel cap
I'm currently working on this Russian alarm clock.
The barrel arbor wasn't well polished and it caused a lot of wear. The barrel cap hole is so worn that the barrel is able to tilt enough to rub the bottom plate.
Is it possible to rebush a barrel cap or is it necessary to fabricate a new cap? The brass is only 0.8mm thick. Is that thick enough to retain a bush? Can I solder the bush into the cap?
2 hours ago, oldhippy said:
If the cap is thick enough to take a bush, bush it.
Thanks, OH.
I will rebush it first. If that fails then I'll solder the bush in. And if that fails, then I'll fabricate a new cap.
On 10/29/2023 at 1:41 AM, HectorLooi said:
Hi @nevenbekriev, in your article on setting pallet depth in The watch Forum, you mentioned Slava alarm clock as a good example to study the escapement due to its size. May I know what model is recommended? Would the model in the picture below be suitable?
Hi Hector,
I see now You have got one of this clocks. It is about 60 years old and made before II Moscow Watch Factory adopt the brand SLAVA. This is the first modification of this movements.
You have done perfect looking job on the barrel lid. Hope that the bush will stay in it's place, if it tends to foll off, then You can solder it. The way to solder it is to enlarge a little the hole on the lid first, so the bush will go in almost free. If tight fit, then the solder will not be able to penetrate in between. Does the barrel rotate true on the arbour now? The most important when placing such bushes is not to loose the center of the hole.
8 hours ago, nevenbekriev said:
Hi Hector,
Edited by oldhippy
2 hours ago, nevenbekriev said:
Sorry if I have done something wrong, but I don't understand what is wrong. Hector asked me before about this kind of clocks and now I see He has got one, (with the same movement), that is this thread about
nevenbekriev, please except my apologies, I didn't realize it was the same type of clock. I have removed it.
I originally put the barrel cap in a step chuck and enlarged the hole to receive the bush. So the hole should have been centered to the barrel cap. But the barrel wobbled terribly when it put it back in the movement.
So, I cut out the bush I put in last night and put in another one. But this time I fitted the cap back into the barrel, then I trued it up in my 4 jaw chuck and finished the hole receive the arbor. It runs true now.
I checked my step chuck just now and I think that it was the problem. For some reason, the step chuck doesn't run true.
Looks like I've got to chuck the chuck. 🤣
Often (usually?) step chucks are soft enough to turn. They have a through-hole of a given diameter, chuck on a piece of bar there, then you can retouch the step/s. Make sure there aren't any bumps or burrs on the cylindrical and tapered portion that fit in the lathe first!
If the bushing needs to be flush on the inside, I like to cut a small step (can be very small, like 0.2mm deep and bigger on diameter), and make the bushing with a corresponding lip, so when all pressed together it's almost impossible for the bushing to accidentally push out.
Edited by nickelsilver
Specially when barrel lid to be rebushed, I make the bush with smaller internal diameter. Then, put the lid in place on the barrel correctly according position mark, if thhere is no position mark - then make one. Next I turn a step on the face of a bar to enter the barrel hole and then fix the barrel on the face of the bar with shellac. Then I turn the internal diameter of the bush to size. This guarantees perfect true barrel rotation on the arbor
Hi Neven,
Thank you for the history of this clock. There was a "2017" molded into the bakelite base of the clock. I thought it was the production date.
The lume on the hands of this clock were replaced with black paint but I see from photos on eBay that the hands were originally lumed. I was thinking of restoring it back to the original look.
Do you think that the original lume had radium?
The natural lume is seen on the dial and it has green color. It doesn't seem to have radium, also they stopped using radium in the 50's and this clock is made later. Do the dots on the dial still shine for some time in the dark right after ehposed to bright light?
Good work with the hands!
The factory existed untill mid 90's and then was closed. In the 80's they started to put plastic wheels under dial and plastic barrel for the alarm spring. When the factory was closed, the movement looked like this and only 2 jewejs left from 11 in the original
IMG_22191.thumb.jpg.c7789e46cea4e42cdcf65105f19a1feb.jpgIMG_2221.thumb.jpg.ec05510efb865148014fd6e7cd419139.jpg
Edited by nevenbekriev
    • The 73 was my setting lever make Mike, same piece fitted to your 72. I enjoyed working on the movement, fair quality. 73 wasn't front loading,but a tight spacer ring that i had to fit onto the movement before casing up. I had to adjust endshake on the third wheel  so apart from the make everthing else was good.
    • Well it's arrived, and it's a pleasant surprise. A 11.5''' 21 jewel FHF 72. It's running (just) and looks in great condition.  It needs a good service, and new crown and strap.  It's a front loader but doesn't have a split stem. There's a small lever (visible when you remover the bezel), which when moved, frees the stem and the movement from the case (a new one on me).
    • Hi All, I'm Geoff and I've been working on/with watches and clocks since I was thirteen. My dad was a watchmaker and while he did not want me in the field as a profession, I've always maintained a pretty good working knowledge. In the '70's I kinda got pulled back into things because Quartz revolution began and he only had limited electronic knowledge. So we combined skills. He the watchmaker and me the electronics tech. Being here in NY helped because we got to know the folks from Bulova, Seiko, Citizen, and WOSIC. H.B. Freid was my Dad's teacher and I was fortunate enough to get to know him too. I still maintain a bench here at home and occasionally work on watches for friends although the hands aren't what they used to be. Not going to be working on any FHF59 or AS1012's any time soon. Oddly enough though my years working with the field taught me how to work on almost anything else mechanical and mostly electronic. Since I was the one in the family who maintained Dad's cleaning and timing machines. those experiences carried over quite nicely into the worlds of recording and audio as well as others. I look forward to the discussions and maybe still learning a trick or two. Cheers to all and nice to be here.
    • The best and almost only way to achieve the magical £ 4.04 individual watch cost is via the loophole ploy of job lot buys Ross. Dividing down the outlay by the number of watches purchased. I've managed it many times in the past, this then gives you the extra edge of choosing any watch from that lot. Maybe we should have an all time winner, whos prepared to troll  through the last four years of posts and pick some worthy contenders. Unfortunately i have a poorly shoulder so i cant raise my right hand and my left shoulder is out in sympathy for my right shoulder. Put your right hand up if you think i talk a load of bull 💩     🖐 Tom's comment is purely restricted to  the Bergeon culture of " lets rip off everyone on the planet " Voted , i thought to keep it in pounds as originally designed and out of respect for Andy . Personally i would have kept the £4.04 as I'm very traditionalist and dont like change but i know how hard you overseas guys are finding it and i believe in fair play. I expect to be posting the occasional Omega or Longines but then you brought this on yourself so dont get jealous Scott 😆
