Hello everyone, I am new to this forum and this is my first post. I bought several old non-working watches to learn watchmaking. Now, I am stuck at the first watch. The watch is a very old Ricoh mechanical.
The movement interacts well with the train wheels and barrels. However, whenever I put the escape wheel, the mainspring barrel gets stuck and so does the whole movement. Without the escape wheel, all the train wheels engage and turns freely.
Any help would be appreciated.
Thanks.
Edited by Reaz
Common faults of this issue are,
 Zero end shake on escape pivot.
Badly bent pivot, thats providing there are two pivots present.
Broken jewel to escape arbour.
Damaged pinion of escape arbour.
Escape wheel rubbing .
I don't pin much chance that picture of the movement shows us the above.
 Rgds
I stopped working on that movement. Instead I started working on a Seiko 6309a and thankfully that movement is running. The tip of the escape wheel was already broken in the Ricoh movement. So, it was dangling around and when it engaged it sat around the center wheel thus stopping the mainspring barrel...
Edited by Reaz
 A true watch repairer  never throws away partially damaged parts.
Thats how he ends up with tons of junk in the box.  lol
Can I even repair that damaged escape wheel? I think I have to replace it and depending on where I live, it is near impossible to source replacement parts without exceeding the value of the watch.
On the other hand, as someone new to watch repairs, I find it extremely difficult to do. I spend hours and hours to nibble certain parts just so it would hopefully fit.
I already had huge admiration for watch repairers and now after servicing few watches myself, I respect them even more.
I thought it was fun but I actually stressed myself out a little bit. 😅
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
