Anyone Worked On A Seiko 7T34 Quartz Movement?
ro63rto
Hi guys. Been doing some much needed gardening.
I'm based in London UK.
Will have to part stripdown to at least test which coils work. Not sure how to test circuit board though.
My multimeter probes are HUGE so a bit of tape and two sewing needles should convert to something I can use.
Rogart, where abouts are you?
It's Sweden here? So not that far of. Both still inside the EU ;)
ro63rto was so kind, in hte end, to send me his watch to fix, since I do have some experience on this type of movement and have some spares, plus he had found an identical watch to use as donor. I will, with ro63rto's consent, publish some pics I took while working on it and also the videos I made to show that it's working properly.
So here is the first pic... This is what ro63rto sent me: two small plastic boxes, one containing the main watc to build, as it can be read on it, and the second containing the donor watch.
I apologize for the slight yellowish color of almost all the pics I will post, since the camera was not quite able to fix the lighting automatically. It is an old digital camera...
I should really post these pics on the walkthrough section...
Anyway, this is what I found inside the "good" watch. The circuit block was completely busted due to acid leak, and the movement presented 2 non working coils and some rust that was blocking the small second wheel to properly turn.
The main plate also presented, on the good watch, a common problem on the Seiko 7Txx series chronographs: the small post on which the setting lever (the squid-like spring) forces onto snapped off. I checked the donor watch and fortunately this post was still intact.
Thanks again George for your speedy work. [emoji106]
Can't wait to get this watch onto my wrist. Out of all the Flightmaster colour combinations, it is my favorite. [emoji7]
If I find any more I'll know who to send them to [emoji6]
ro63rto it was a pleasure working on this watch. I love working on them, and even if sometimes it is a bit hard they are still pretty serviceable. Professional watchmakers tend to avoid them, suggesting to swap the entire movement... This is getting harder and harder to do, since they are not in production anymore and if you do find a NOS movement it will cost you sometimes more than the watch itself.
It is always a matter of answering the question: is it worth it? For me, servicing them (and not just swapping the movement) is worth all the effort. but it is just my opinion...
43 minutes ago, ramrod said:
that is a beautiful watch. i love the color combo. is the spare worth saving also?
I am working on it actually... The circuit block obviously not, and it will need 2 new coils too, but as far as the movement mechanical parts, they all seem in good order. The case though has special needs, being badly scratched and the glass will need to be replaced too.
It's here, it's here, IT'S FINALLY HERE [emoji7] [emoji7] [emoji7]
No thanks AT ALL to MyHermes [emoji35]
Disappeared off their tracking on 18th July. Even they couldn't tell me where it was.
A big thanks to George for the work he put in to get it running. [emoji144]
Now the hunt begins for a worthy strap.
A big thanks to George for the work he put in to get it running. emoji144.png
Finally! This is actually a big relief that you finally got it in your hands....
Hope you are satisfied with the "treatment" it received in my hands (of course, not in Hermes hands...) and that the strap you find will make it pop on your wrist, like it deserves!
It is a wonderful watch, and if Hermes people were not too rough on it during the shipment, it should last you decades more.
Regards.
Think I may have found the right strap for this watch.
There's a guy on another forum that custom makes leather straps to your size and design/finish.
He just made this one for a member.
I think I will save up and order this with green stitching to match the main chrono hand.
Wow that strap looks great! Care to share more info on price (if allowed...)?
No idea. As each one is scratch made etc the cost varies depending on leather used and what finish etc. All is dealt with in PMs and no one tells how much they paid.
One repeat customer did hint on cost by saying he had to choose between replacement refrigerator hinge or the strap. The fridge won. [emoji1]
I might as well imagine the conversation of that customer with his wife, on which was more inportant... :D
If you do buy it, please do not be so secretive and disclose at least if it is in the tens or hundreds.... :P
Edited by GeorgeClarkson
I might as well imagine the conversation of that customer with his wife, on which was more inportant... [emoji3]
If you do buy it, please do not be so secretive and disclose at least if it is in the tens or hundreds.... [emoji14]
I'll certainly let you know.
I really like that strap and think it will suit it perfectly.
Have one of this. Have been working on it but can't get the alarm to work? Had one recently that i changed the battery on? There was a alarm sound when i pulled the crown out? My watch doesn't. Where should i start looking? DSC06820.JPG
Edited by rogart63
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
