Accutron 2181 Repace pawl finger (how to)
  • LittleWatchShop changed the title to Accutron 2181 Repace pawl finger (how to)
Ok, maybe I was not clear. @ManSkirtBrewyou are correct. I just pried it off. The whole unit comes off as @HectorLooisaid but that was not what I really needed to know but was the correct guidance.
I have a donor, but I see that the finger is bent around the collet making it too short to hit the index wheel. I have removed the finger from the plate. Next, I will straighten it so that it will intersect the index wheel properly. But will wait until tomorrow when I am fresh!
Edited by LittleWatchShop
An update. On the donor, pawl finger, I was able to straignten it out.  The images show what I mean (I show a bent one and a straightened one...just the finger itself and the collet).
The collet was loose so I had to compress it.  I used a collet-closing tool I bought for hairspring collets.  Very handy!  It also held the collet while I was doing the bending.
It was trial and error getting the collet back on and at the right height to properly hit the index wheel, but I got it pretty close to centered.
The watch kindof runs though it appears to lurch slightly at the frequency of the index wheel.  I think that maybe the index wheel has some damage.
Another indicator is that the current on the test set is fine while the pawl is not engaged, but once engaged, the current goes just beyond the threshold for the 218.
It is a learner watch, so I continue to learn!!
Apologies if you already know this, but the recommended procedure is to seat the collet all the way down and bend the post back or forwards to raise or lower the jewel.
My experience has been that the index wheels are always out of round. This can make it challenging to get it to run smoothly.
In this video of a 218 I did, you can clearly see the wheel pulsing back and forth:
And in this video of phasing a 219, you can see it fully stopping at the high points:
Are you phasing with the battery, or with a variable power supply?
Further observations:
The Accutron 218 movement holder (I inherited) is far better than a conventional movement holder.  It clamps on to the movement very secure.
Second, I do not know how anyone could work on one of these without a microscope.  I have the Bulova microscope but I am using my stereo for this work.
Using a battery installed on the test set.
Yes, I read this but forgot it.  I will revisit this issue today.
The couple that I have looked at also corroborate this.
On 12/13/2023 at 3:55 PM, HectorLooi said:
Use an oiler to turn the pawl finger away from the index wheel first. Then remove the two screws holding it. The pawl can then slide forward, out of the groove of the eccentric adjusting screw.
@HectorLooi, I asked @ManSkirtBrewabout his Accutron cleaning method and am curious about yours. He uses ultrasonic and L&R clean/rinse
This seems scary.  The index and pawl fingers vibrate in the watch, so I guess vibrating in the US is OK.  Still seems scary.
It's scary to me, that's for sure. The only thing I leave on the mainplate is the index wheel. I reinstall it and the upper bridge, then put them in their own basket.
The fork and pawl bridge get separately cleaned in fresh hairspring dip.
Edit: from the 218 service manual:
Edited by ManSkirtBrew
Hopefully it's okay because typically I always clean tuning fork watches in the cleaning machine with ultrasonic. Always clean the index wheel in the ultrasonic. Always try to remember not to clean the tuning fork because it's amazing how much metal particles floating around in the cleaning machine.
    • Personally I would just replace like for like.Or just polish the old crystal and refit.
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
