Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.Â
By watchweasol · Posted
Welcome to the forum glad you are enjoying it . The more you do the deeper down the rabbit hole you go.. there are many good books and plublicationsavailable on the subject of Horology. Ones by Henry B Fried well worth reading. Attached a document for your interest. TZIllustratedGlossary.pdf -
Hi welcome to the forum, Â please feel free to document your failures as well as successes as from both members can learn what to do and not todo. Â There is no question on earth regarding watch repair that is stupid or irrelevant. What ever you will get an answer. attached is a file to help you on your way. Â TZIllustratedGlossary.pdf -
Hi And welcome to the forum, best watches to train on are cheap but working watches as if they don’t work after your ministrations it’s your fault. Getting broken watches defeats the object. When you work on these and they don’t work afterwards you don’t know whether it’s what you did or was it knackered before you started , so try and make life easier without accumulating junk. Attached a file which is worth going through TZIllustratedGlossary.pdf
