Well, this is my first post at this forum. I am a watch hobbyist / repairer.
The photos attached show an Illinois Sterling pocket watch that is of sentimental value. The movement has the markings:
double roller
4338188
Adjusted
Springfield
The movement appears to be in good condition (needs a cleanup and oiling).
The problem is that it has a broken balance staff (pole). I cannot source this so any help will be most appreciated. I know this is an old movement and I understand that sourcing parts is not easy, but nevertheless I am giving this a go.
I am also unsure if the bend at the balance spring indicated with a red arrow A in photo img_0332.jpg is normal or distorted, so any adice is most appreciated.
Thank you
post-1084-0-12342700-1440943596_thumb.jp
post-1084-0-72143100-1440943634_thumb.jp
post-1084-0-11085100-1440943785_thumb.jp
Finding the correct pocket watch balance staff is extremely difficult. The last time I had to replace a pocket watch balance staff I modified one from a batch of staffs I had purchased off eBay. You will need a watchmakers lathe or jacot tool to achieve this. The other alternative is to find a donor movement .
If you can research & find the company that made the movement then you could try this company:
http://www.balancestaffs.com/balancestaffs.php
Many thanks for your reply :)
It seems that this is not going to be easy, but I may need to do quite some research on the movement. The website you indicated seems to be the right place :)
best regards
I suspect it is a Breguet Overcoil spring, although it is hard to be certain looking at the photograph. Have a close look at the hairspring and see if the shape complies with this shape http://www.faqs.org/patents/imgfull/20110199866_02 It probably won't have the link indicated at 9 on the diagram.
According to S/N number in database its grade 405, 12s from 1923, so look for staff on ebay for this model, also some details are in Swigart catalog, like part number. Im not Illinois watch specialist, but maybe we have someone who is. You could also check nawwco forum and ask for help with that.
Thank you so much.....now I have some interesting information on which to base my research. I believe it is a Breguet overcoil :) So no problem with the hairspring - thank you Geo.
Many thanks also to Rafal......I'll try using your information. I have no such detailed catalogues :)
I'll write again and let you all know how things proceed - my watch work is my hobby, my free time at the moment, is rather limited but I'll post again as a follow up on this :)
Regards to all
Without fiddling around I can tell you the hairspring is correct. If you have no luck with the balance staff see if there's a watchmaker near you who could make one.
Well, I'm not sure if I can find a watchmaker, here in Malta, who can produce watch parts. I may have to send the watch abroad for that kind of work. However, I'm trying to leave this option as my last resort :)
on 2nd page catalog I posted you have listed diferencies from other models, and balance staf is not there. I dont have much experience with Illinois watches so, maybe someone could confirm if thats ok (if that would be South Bend - thats a different story :) )
Edited by Rafal
  • 1 year later...
Hello again....I have shelved this work for a while. But somehow I found some motivation and established contact with this guy:
http://www.daveswatchparts.com/
He seems to know the type of balance staff that I need for this watch. I bought the staff and its on the way now. I will measure and compare it with the original and see if he got it right or not.
I will write again after receiving it.
Regards to all
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
