Timegrapher show -220 watch runs +1 hour per day fast
That is not a split stem. Cheap watches do not use split stems as that costs money. The correct way is to pop the back off and release the stem. The battery is also accessed via the back. When you get your caseback knife, practice on the old watch first. And another advice I almost forgot to give is... if it's that difficult to open, it'll be difficult to close. You'll need a caseback/crystal press. -
Thank you for your help. I had to pop the bezel off. It was easy... then I tried to loosen the stem. I pulled on, apparently to hard, and I think it broke. had the tilt the guts out and slide out the stem. I think I am going to find a similar watch and swap the dial. I put a hurtin' on that case and the crystal had a crack. Live and learn. I appreciate all of the help you provided.
There isn't much evidence at all to say they were , just that little piece of info , no idea how accurate that might be but i could not find anything else. The two watches are curious though , both claim to be Olympic editions and they're surely from the same factory the design is almost identical with a slightly different case, maybe just a one collaboration that has been made out to be more than just that. -
Direct is my middle name, if you want direct then call me, i am as direct as direct can be, master of directness, if i was a phone book i would be "THE DIRECTOR OF THE DIRECTORY" if i was traffic controller i would be " THE DIRECTIONS MANAGER " I was gonna join the pop group " One Direction " but they wouldn't let me change the name to " Only Rich's Direction " -
Ok, sorry, I have underestimated You skills. What You describe, that the rack tail goes under the snail, may be is because someone has hammered thinner the rack tail in order to elongate it, which sometimes is needed for adjustment of correct strike numbers. If the snail/star wheel has big free play, then decision is rather to make new post for it. I am curiose to see how much the free play is present there. The post and the bearing are made of steel and will never wear, unless someone will decide to ream the hole. What is the free play of the bearing/post of the lever on which the snail wheel sits? But may be the beter way to solve the problem is to bend a little only the tip of the rack tail up.
