How ETA (2824) is the Breitling Cal 17?
Hello friends,
A friend of mine has a Breitling Colt Ocean with the Calibre 17 / B17 which based on an Eta 2824-2. The link here speculates on the modifications that Breitling may have made: http://www.donindiano.net/watches/breitling/superocean/b17_movement
His watch doesn't run and has some water damage (extent a bit unclear). It's currently at Breitling for a quote... they said 1000 EUR and they want to swap the whole movement. 😅 I say "THIEVES!".
From the two (bad) picture I have (see below), I feel that it can easily be saved with some love and care (and Evaporust and glass fibre brush).
But question: if I need spare parts, can I just get the ETA 2824 pieces? Or would you expect any incompatibilities (apart from external finishing maybe)?
Thanks and best regards,
C
IMG-20231023-WA0002.jpg.fb7f2c99aa6dac51ccafb56abde61ec0.jpgIMG-20231023-WA0003.jpg.d54245530bff692d32ada567b2e02892.jpg
Edited by Knebo
Looks to be a standard chronometer/top grade, the only Breitling specific part being the engraved rotor. The rotor bearing can be replaced if needed, and parts should be readily available. Swapping the whole movement isn't out of the ordinary for such a piece, but 1000 bucks seems quite high even counting they fully refinish the case. I recommend finding an independent watchmaker to service it, should be around half that price especially if leaving the case as-is.
  • Thanks 2
 I would have refered your questions over to Master Nickelsilver because I simply didn't  know the answers to such detail,  parts to it are interchangeable with lower grade ones and good to know they can be sourced.
Reversers are sure to need attention or replaced with new.
Rgds
Thanks for that!
Yes indeed, I am offering my friend that I do the service.
It's a COSC certified chronometer. The chronometer number is engraved on the trainwheel bridge (you can see it in your picture). The rotor is engraved.
Aside from the movement carrying a chronometer certification, it is a "chronometer grade" 2824-2 and will fit any 2824-2 parts without issue.
14 hours ago, Nucejoe said:
Check this,
and I have a question, this guy thinks everyone knows what anachron hairspring is, I DON'T. 😩
https://calibercorner.com/eta-caliber-2824-2/
TIA
"Anachron is said to be a better performing alloy than any Nivarox incarnation which is why it's used on the Top and Chronometre grades." Link here.
Considering it's a luxury watch and movement, just don't go to town with your glass fibre brush. If unsure, take a very light brush under strong magnification to see what it does.
Thanks for the advice @VWatchie. I always appreciate you inputs.
My plan, if I get the watch, is to try EvapoRust as the primary method. The glass fibre brush only where that hasn't dissolved the rust.
16 hours ago, Nucejoe said:
Thank you @VWatchie
One more question,
How do you activate a link ( as a radio button )
 I mean  this      " LINK here
TIA
  1. Find the web page you wish to link to and copy the URL (from the address field at the top of the browser)
  2. Mark the word or words in your post where you want the link (in your example the word here)
  3. Click the Link button at the top of the editor (opens the Link window)
  4. Paste the copied URL into the field with the label URL and click the Insert into post button.
Hope that answers your question!
    • Hi John, The most important parameter of the spring is the thickness. The lenght is something that one would not consider as obligatory, as relatively big variations will not affect anything in significant way. The barrel size is related to the barrel and has nothing to do with the spring. Yes, the spring is designed to work in a barrel and the size of the barrel matters, but let this parameter be chosen by the movement manyfacturer, not by the sping manyfacturer who doesn't have idea in what kind of movement the spring will work. Sometimes the washer in which the spring arrives will be bigger than the barrel and there will be no way to just push the spring in the barrel and be happy. Well, if this is a problem for somebody, then probably He is a person with to many problems that will be verry hard to help to in any way. By the way, why You are changing the spring? Is the old one broken?
    • Lets give it to the end of this month to get all the votes in, then we can call it?
    • OK, I have created a solution to the above, I have made a fake protonmail account, if you PM me I can send you the password, just click on the contact link and enter your information, this should be as secure as it gets:   Website:     Link Login: email as highlighted in above screenshot WRTArk    @   Proton.    me Password: ..........PM me and I'll let you know   Only intend to use the contacts function, not the email or anything else - we are all grown ups, please act responsibly.
    • I went with 8.90£ because 12th century Italian mathematicians are always excellent topics to bring up when trying to get your guests to go home.
    • As a beginner, I’ve found this forum invaluable. I doubt I would’ve persevered without its support. I’ve had the confidence to attempt things that seemed to me impossible only because I knew there were patient and giving folks gathered around this watering hole, available to share their skill.    I would very much like to know where to go if this one dries up and everyone needs to decamp.  There’s something special about the folks gathered in this group.  How to keep in touch?
