Seeking buying advice: Jacot tool
26 minutes ago, nickelsilver said:
I would certainly have been ahead money-wise had I waited and gotten a good full set in the beginning...
Undoubtedly, but it is of course a matter of balance. For how long are we willing to wait for how much money? Not an easy question. Life is unfortunately short and the path to skill is endless so better get going with the means you have at hand than wait until it's too late.
21 hours ago, nickelsilver said:
Wooden box is newer style tools, black box the older style. The newer style has the advantage that the alignment of the headstock runner can be adjusted if needed. It's generally not needed, but if it is, you can do it. On the older tools there's no way to adjust
Thanks! The wisdom in this forum never ceases to amaze me.
15 hours ago, VWatchie said:
In case you do have unlimited resources, and I hope you and everyone else have, you can always place an order here 😉
The cost of new tools is the second thing that never ceases to amaze me (in comparison with the cost of used ones, particularly) 😅
My character challenge is that I'm perfectionist (as in, I want the best tool for the money I have) AND also impatient (can't wait indefinitely until something comes up). It's a tricky combination, hahaha 😅🫣
I'll spend a dozen hours searching all platforms (not only eBay, but also the local/national classifieds websites in nearby countries like Germany [kleinanzeigen.de], France [leboncoin.fr], Switzerland [anibis.ch, ricardo.ch], Austria [willhaben.at], Belgium [2ememain.be]...). On that note, I can really recommend the German and French links. A lot of good stuff to be found (if you know the words to search for)!
For that reason, in the end, I may go with this approach:
Or, in the meantime, get a Jacot in good condition for little money (even without the centre wheel runner) and then resell it once a better option surfaces.
Oh boy, I'm really cracking my head over this now 😑
I'm in between two offers. Both are the old style Steiner tools in the leathery box.
A) full set WITH the center wheel runner. Overall condition 8/10. Lanterns are 10/10; runners 8/10. It has a bow, but NO "PULLEY" mechanism.
B) small set WITHOUT center wheel runner. Overall condition 9/10. Lanterns are 9/10; runners 9/10 condition. HAS PULLEY mechanism instead of bow. And I think it has a very thin "self made" burnisher included (meaning, the previous owner took something like a steel rod and files/sanded it down). See image below. Or is this something else? Could it be a usable burnisher?
Ok @Knebo, lets keep it real. You have just gotten into watchmaking. You don't need a Jacot tool. You'll end up breaking more pivots than improving them.
I have a Jacot tool but I hardly ever play with it.
My mentor does repivoting, cuts balance staffs, cuts wheels and pinions and he doesn't even own a Jacot tool.
If you are buying it as a collector's item, a conversation piece, then go ahead. But a hobbyist would rarely need a Jacot tool.
Perhaps the more senior members of WRT could jump in and advise you.
Haha, ok ok. Thanks for the reality check. I actually appreciate it  -- and I must admit that I've wondered about this too. You are probably right😪..
I'm just very enthusiastic and the tool-addiction (more, more, more!) has hit me hard.
I make a lot of staffs and do a lot of pivot work and there's no way I would be without a Jacot tool (as mentioned, I have a number of them). It's how pivots are finished at the factory, and by far the best and easiest way to get an excellent finish on a small diameter. While the old style are perfectly good, I would stick with the new style. The ability to tweek the alignment if needed is well worth it.
Yikes- that’s a bit harsh. Nobody is born a watchmaker and as a fellow hobbyist I’ll say you have the luxury of pursuing what interests you- if you’re enthusiastic about it please enjoy!  There are clear benefits to amplitude and longevity of services if you acquire the skill…
…and speaking of tools you don’t need I would have delayed the one everyone is quick to acquire- mainspring winders. The packs with the spring in a lovely washer are quite inexpensive and given most of the watches I work on have worn out old style carbon steel springs I’m not certain I’ll live to see breakeven on the winding set…
…then again, the Vulcain on my bench is rebanking because the recommended spring size is discontinued so I went up ever so slightly 🙁
I am pretty sure my dad never used the Jacot (even though he had one). He had a retail business that depended on throughput (in order to send three kids to college). He replaced a lot of staffs, but back then replacement parts were plentiful and locally sourced (Houston, Tx). The tools I inherited did include an Elgin sapphire burnishing tool that appeared to be well used (the plastic caps were repaired multiple times it seems). So, he must have done some fine tuning.
At any rate, it is an interesting tool and I will continue to learn how to use it effectively.
I know my advice sounded a bit harsh but for a beginner who hasn't developed the fine motor skills required for working on pivots as fine as 0.12mm yet, I think my advice is justified.
For the same reason, I don't advise beginners to do hairspring adjustments. The motor skills required for such jobs have to be developed over time.
The cost for a decent Steiner Jacot tool is around $600 at the moment. I think the money could be better spent elsewhere, like better lighting and a microscope. I would say that the microscope is the biggest game changer in watchmaking. It takes time adjusting to working with a microscope but I think the learning curve is not too steep and the gains far outweigh the inconvenience.
And I think a microscope actually helps to develop fine motor skills.
I think the reason why I don't use my Jacot tool much is because I find it difficult to work the Jacot under a microscope.
And the tool addict in me is telling me to get a Jacot drum for my lathe and get another microscope with a swing arm. 🤤
Edited by HectorLooi
Typo
I'm not sure I get this. I've been looking at my "newer style" Steiner but can't quite figure out how and why the headstock runner would be adjusted.
I've read the posts regarding the do get or do not get a Jacot tool with great interest and I can both understand and agree with some of the arguments, but I would probably say that in the long run, a Jacot tool and learning how to use it is crucial to getting optimal results. Here's a happy example!
Yes, learning how to use a Jacot tool is a pretty big investment. It can be extremely frustrating at the beginning when the burnisher slips and you either destroy or damage the wheel arbor, but we are all beginners at some point, so the sooner we start, the faster we gain the necessary motor skills, experience and knowledge. In short, there is rarely much to be gained by waiting.
I would think there is complete consensus that we all feel that it is of the utmost importance to be thorough in the cleaning and pegging of all jewel holes, but if the wheel pivots are badly oxidized, rusted, scored, or deformed, there will still be friction in the wheel train and adversely affect the performance of the movement. Worthy of reflection is that assuming we are serious, we would never consider not replacing a cracked jewel. Similarly, we should not consider not fixing a wheel pivot that is not in perfect condition.
Still, I have to agree that there are a lot of other things to focus on before acquiring a Jacot tool (like getting a stereo microscope). In the short term and as a beginner, an option may be to completely replace a train wheel whose pivots are in poor condition with a brand new train wheel if available. You can also get quite far by making sure to be extremely thorough with the cleaning of the pivots. If they are not rusty, badly oxidized, scored, or deformed, it may be enough to polish the pivots with Eveflex.
I have to say I am amazed at how well Eveflex can clean. Eveflex can make a pivot look brand new. The disadvantage of Eveflex is that they have an abrasive effect and can if the polishing goes on for too long, make the pivot tapered. In this post, I have summarized my experiences with Eveflex. Important to note, however, is that Eveflex cannot in any way replace a Jacot tool when it comes to repairing a pivot.
To summarize. Yes, if the pivots are badly oxidized, rusty, scored, or deformed, we have to fix them with a Jacot tool.
Edited by VWatchie
Replaced the word "scratched" for "scored"
If you look at the headstock end with the pulley and runner removed, you see a sort of V block in there. There are jack screws at each end, with holes around their head permitting a rod to be used to turn them. Tightening them pushes the block upwards, loosening (and then inserting the runner and firmly tightening its lock screw) pushes it down. The V block is slit along its length allowing it to flex, thus being able to move up or down in the round bore. This is for the vertical alignment. Then, a simple tool can be inserted to rotate that block in the bore, which gives the lateral adjustment. Some tools have a more obvious vertical adjustment (see pic), those dispose of the jack screws but the lateral alignment can still be done.
To check the alignment I just use a wheel with the shortest possible pivot to pivot length, and put it in the tool (check that the wheel is true!), and see how it looks compared to the tailstock runner face. The short arbor magnifies any error, and if it "looks" good in the tool, that's good enough.
One thing I have seen on many of these is the simple headstock runner is bent. To check that I put it in collet in the lathe, and check. I use a dial test indicator, but again, if it looks like it turns true just visually checking against the T rest or something, that's probably good enough. Truing it is simply a matter of bending it the right direction. I haven't broken one yet.
As to why Steiner moved to this design- I imagine it makes it easier to produce, as things are less dependent on getting the hole for the headstock runner absolutely perfectly placed. And it just nice to be able to adjust things if and when needed.
Edited by nickelsilver
  • Thanks 2
Very interesting.
Funnily, this makes me want to buy the old version. I feel like there's less risk of any misalignment and me not managing to correct it. 😅
  • 4 weeks later...
I had resisted the jacot tool buying urge for a while now, but just came across a potentially good offer.
I remember the brand "ECS" being mentioned in one breath with Steiner, as if they were the same or compatible with each other. But ao can't remember where I saw that. Can anyone confirm /enlighten me?
Here is the tool and the logo:Screenshot_20231112_212649_eBay.jpg.bf438f23964b51ccf97d0f7bd3a4b4e4.jpgScreenshot_20231112_212748_eBay.thumb.jpg.a41f563979be0fe487f873abcc5563f1.jpg
So, I have some news about the ECS jacot tool from a French watchmaker:
"This E.C.S tower is 2nd generation, certainly manufactured by Houriet & Cie in Tramelan (Switzerland) in the years 1940/1955.
The company was bought in 1989 and became Horia Steiner Company.
See this link: https://www.horia.ch/fr/L-entreprise/Historique/Historique-HORIA-SA.html
E.C.S lathes are beautifully made pivoting lathes, identical in their use and precision to the latest generation Horia/Steiner lathes.  Another advantage is that they have the same spindle diameter and are therefore interchangeable."
  • 3 months later...
Sooo, after initially following @HectorLooi's advice and kinda abandoning this project and then following @VWatchie's advice of waiting patiently for a good deal on a complete set, my moment has come:
For an incredible 125 EUR, I managed to get a pristine (basically unused) "new style" Steiner set. It's the large set with the center wheel runner. In addition to two perfect lantern discs (hidden under the covers), a another perfect pair of spare runners were also included.
The burnisher was not included, but after such a bargain on the tool, I treated myself to a new Bergeon burnisher. And a pair of retractable keyholders ;-).
Now I need to practice.
20240303_133238.thumb.jpg.ef2468c2c9bc20f452a07b7680f49be3.jpg20240303_133247.thumb.jpg.b102abb6b36fd741df716fac10d6de66.jpg20240303_133312.thumb.jpg.ea28165c1f31b30b32cc8c93cead4e5e.jpg
Edited by Knebo
  • Like 7
Yes, that is incredible! I thought I had the record of paying merely $200, but obviously not 😉 Congrats! 👍z
BTW, if you don't get any use for the bow, drop me a PM!
    • Hmmm you know when i said some damp might have caused the bubble originally hmmm 🤨
    • Are you all jerking my chain, I'm a yorkshireman £4.04 is too much 😆
    • [Myota2034] Custom simple quartz watch — PricewaterhouseCoopers On a very very different note, here is a watch from approximately 2000 when I was a Partner with PwC, Management Consulting. It was a simple “marketing watch” with a clever “vase of knowledge” that is subtly revealed on the dial as the second hand progresses. Clever for a simple watch!⌚️
    • I think someone else has though. Some where here using a modified perspex sheet. I may be wrong i may be right , i think it involved fitting the arbor to a pin vice. I dont have experience of the bergeon winders, are the handles not interchangeable ?
    • Never tried dial dots, i always considered them as a bit of a bodge.  You are adding something that was never intended to be there. I wonder how the adhesive reacts to any part of the movement, hot summer heat and i think things might turn sticky. Most adhesive backed stuff has a tendency to soften and slide around so it may spread, i have used a lot of so called sticks all adhesives in my industry that are just not up to the job. I suppose they get you out of a problem quickly, but how permanently might that be ? I would just explain to the owner that it may or may not work. WWs other ideas are a much more permanent solution but both have their risks . I've tried milling and dial feet replacements, hmm it was ok, ive heard of folk dimpling the face , so that needs care . And i have soldered a few times , all with good results but i am very careful and I practiced it a lot.
