I took apart my pocket watch today, which would just spin the hands very fast when wound. I looked at the Center Wheel, and noticed that if I apply a little pressure from the top on the Center wheel on the mainspring side, it would grip onto the mainspring and wind. What is wrong? The Center wheel doesn’t seem to have a jewel, but a metal “bearing”.
12 minutes ago, Markus080607 said:
 What is wrong?
Don't know. Can we have a pic please?
It's very common to have a metal bush on the centre wheel.
Edited by mikepilk
It sounds like one of the wheels is not meshing and bypassing the escapement somewhere, probably the forth wheel and escape wheel.  I  bought a cheap watch that did the same thing, the pallet was missing.  By pressing, you maybe getting the wheels to mesh.
We do need photos.
Unfortunately the word pocket watch is a very very very huge category of watches and we need a little more to go on. Maybe background history of your pocket watch what was it doing before it started misbehaving. Then definitely pictures to narrow down what it is as not only is it a very huge category but it spans a very huge time are we talking vintage modern we need pictures and better description.
I also took a video of a bit more details, but wasn’t able to upload it. I can send it on gmail, WhatsApp or something else if anyone needs it!
When you're taking a pocket watches apart is there a reason for it? In other words is there a problem that you're trying to fix or what
We need a full picture of the movement not bits and pieces. Otherwise you'll be unhappy with the answers we give you. As you took the watch apart how but giving us a picture of the center wheel? In other words the center wheel out of the watch. Then yes some watches don't have jewels some do it depends on the watch that's what I meant by that is literally thousands of variations of pocket watches.
So we really need a picture the center wheel out of the watch
otherwise as I said we can guess like if this was an American pocket watch there would be a reason for this but I doubt it applies to this watch.
I can’t get the canon pinion off, so I can’t disconnect the Center Wheel. Could that be linked to the issue?
On the discussion group like this when you run into a problem you could ask for for help like oh dear I don't know how to remove this? Then the suitable pictures we can verify something as opposed to I get the guests and let's see how good I am at guessing based on the age of your watch.
On the other side in the picture that we don't have doesn't look something like this? In other words smooth sides probably a protruding pin?
A lot of times on the other side it will look something like this where you have to look really carefully to see that there is a pin and that has to be removed to get the Canon pinion off
In the evolution of these components at one time this would've had key setting the key would either go on the front side or the backside here's an image of key set on the backside. Now while yours is not a key set the principle is the same there is a pin that goes through the center wheel and holds the Canon pinion on at least that's my guess based on the lack of pictures and your inability to remove the Canon pinion because it is not a normal Canon pinion which is still subject to me making a guess due to lack of pictures
Here's a picture of a book that should represent what you have once we verified that is what you have I will explain how to take the pin out
Oh and typically make repairs you need to take the watch back out of the case.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
