Help needed with fusee movement
Rixy
I have been asked to look at a clock for a friend. He says it runs quite well when partly wound but does not run for long when fully wound. It is a fusee movement and I have never had a go at one of these so would appreciate any advice. I have read that it must be let down by removing the pallet and allowing it to run. Is this correct? Do you think I should clean the parts in an ultrasonic cleaner?
Have attached photos if that helps.
All advice is much appreciated. 20230826_173454(0).thumb.jpg.90239ca3c4fd603442c166ed1d17ae0f.jpg20230826_173536.thumb.jpg.e9353ccd90c2cb903f8ad62f29c05cb9.jpg20230826_173621.thumb.jpg.c0e533ea0847de74e011046ef5258601.jpg20230826_173558.thumb.jpg.d8118f461c82c1b12dd90720d7d785ae.jpg20230826_173547.thumb.jpg.6dd825f5f043682fbba956d3ce9c85c5.jpg20230826_173628.thumb.jpg.afeb244434b5585858945407d1cc5c6f.jpg20230826_173512.thumb.jpg.cee18935fd729bfa8f1621acc8ccd566.jpg
First of all this has had a service not that long ago. The movement is clean and the steel pins are new. From the photos I can see that there is a lack of oil on the escape wheel and the pallets. Make sure you have oiled all the pivots first, then remove the pallets and let it run down. There isn't that much power on as the fusee cone has most of the chain on it. Never use an ultrasonic on clock of this age. Check the two screws that screw the pallets to the crutch, if they are not tight they will cause a poor action enough to stop the clock. Are you sure it is in beat and that the wall is flat up against the back of the case. Clock movements that are clean usually mean trouble so look for worn holes, bad pivots, make sure all the wheels run true and check all the teeth. Barrel and fusee holes and pivots I know they are big but check for roughness and fitting. Look at the chain are all the links free and in good order. The spring should be removed so a good mainspring winder is needed so you can check it. I t could be warped  or tired.
Thanks OH. Especially about not putting it in the ultrasonic - I had a feeling it would be best to avoid doing that. I'll check over those things and see how we go. You could be right about it not being in beat - there are wall fixings on the base that he said he didn't bother with.
I'll update as I go along.
Well I took it apart and cleaned it all by hand (nowhere near the ultrasonic!) and reassembled it. Had to do a bit of research on how to reattach the chain but got there in the end.
Oiled the chain, checked the mainspring (it seemed fine) and oiled the pivots, the escape wheel and the pallets. Loaded a half turn on the mainspring and secured the click. Have set it up for testing and it has been running for about 3 hours now. So far so good...20230827_142118.thumb.jpg.e3be012f7a92db95059e25df42fd1ba1.jpg20230827_194518.thumb.jpg.482f95463eaa0588bf03d0d4ca5973b4.jpg20230827_194507.thumb.jpg.55d15f51aae5c23c1e45a891e0030eb9.jpg20230827_211016.thumb.jpg.40ea55020b08c1d3f5166fa6a622c73e.jpg
If you push the pallets right over against the pallet cock are the pallets still catching the escape wheel teeth. Or are the teeth just catching if so this can cause wear on just part of the teeth of the escape wheel, you need to move the pallets over.
On 8/27/2023 at 11:15 PM, Rixy said:
Onu parçalara ayırdım ve hepsini elle temizledim (ultrasonun yakınında hiçbir yerde!) ve yeniden monte ettim. Zincirin nasıl yeniden takılacağı konusunda biraz araştırma yapmak zorunda kaldım ama sonunda oraya vardım.
Zinciri yağladı, ana yayı kontrol etti (iyi görünüyordu) ve pivotları, kaçış tekerleğini ve paletleri yağladı. Ana yaya yarım tur yüklendi ve tıklamayı güvence altına aldı. Test için ayarladık ve yaklaşık 3 saattir çalışıyor. Şimdilik fena değil...20230827_142118.thumb.jpg.e3be012f7a92db95059e25df42fd1ba1.jpg20230827_194518.thumb.jpg.482f95463eaa0588bf03d0d4ca5973b4.jpg20230827_194507.thumb.jpg.55d15f51aae5c23c1e45a891e0030eb9.jpg20230827_211016.thumb.jpg.40ea55020b08c1d3f5166fa6a622c73e.jpg
Hello. What oils did you use in this mechanism?
What is the recommendation for the winding spring specifically?
    • @Jon The link is no longer working and I wanted to see that demonstration again. Is there any chance you can make it available again? I'd appreciate it!
    • Or, if you have a staking set or jewelling too, just use one of the stumps. You can choose a fine tip to fit inside a jewel if necessary.
    • Good morning,   To be honest, I'm not sure I trust my own logic anymore 😅. But here's a picture of my own (failed!) attempt to install a new rotor axle. I punched way to hard and even split the metal of the rotor. My thinking was that, in my case, the axle sits "deeper" in the rotor and hence the rotor would be closer to the movement plates. Vice versa, I was thinking that a very light punch could cause the rotor to sit rather high. But not sure that makes sense because in both cases, the flat part of the axle and the rotor align equally.     Sorry, but is he saying that the outside of the caseback has been polished to such an extent that the inside of the caseback has deformed/sunk??? That sounds crazy to me because those casebacks are thick! Can you see any signs of that on the inside of the caseback? Have you tried screwing in the caseback a litte bit more or less so that the supposedly "sunk" part of the caseback would move from 9 o'clock to e.g. 6/7 or 11/12 o'clock?  If the caseback is truly deformed, maybe it could be punched/pressed back into shape (e.g. with glass/caseback closing press).      I agree with your choice. But yea, Rolex makes it VERY hard for independent watchmakers to do a perfect job because we can't get (original) parts easily.      Your pictures aren't too bad. But still impossible to see if the rotor isn't perfectly flat. You'd have to look at it with your loupe, from the side (like the pictures), and turn the rotor to see if the gaps (with the automatic bridge plates) increase/decrease.     Finally... how is the up/down play of the rotor? To test, take a toothpick/pegwood and press on the small triangular side of the rotor next to the axle (NOT the big side where the weight is. But the opposite side.). Does that lift up the weight-side of the rotor? There can be some play, but it should really be minimal. If there's too much play, a new spring clip is the first thing to do. After that, one could play around with the jewels. This is too much:
    • could start a new sub-brand: Bergeon-Pro Worked for Apple phones! Ah they already beat me to it:
    • Hello, those RR pocket watches are nice watches, there are still parts around...
