Certina ETA 2825-2 , grade of the movement.
 ETA 2825-2  comes in , standard, elabore, top grade and Chronometer grade.
I have a Chance to buy this at a discount, have asked the seller for a pic that balance can be seen in, plus numbers on the back plate so I can confirm genuineness and the grade.
https://esam.ir/item/25970815/ساعت-سرتینا-DS-4-اتوماتیک-اورجینال
Can the grade be recognised by other features ?
Appreciate your opinion and pray God  blesses you with five more kids.😁
Rgds
I think the difference between standard and elabore is that standard has no  decoration. There is a difference in number of adjusted positions 2 vs 3 respectively. I seem to remember being told the only difference between top and chronometer is that the second has done full certification.
this link has more information and might help Joe
https://calibercorner.com/eta-grades/
Tom
Thanks Tom,
Here is a clear picture of the back plate seller sent me, winder rotor is the new fancy color I am not familiar with . have seen some chrome plated ones have some decoration on the rotor.  no decoration can be seen on this movement and the sticker obstructs the balance, if glucydur it be 3 adjustments.
https://static.esam.ir/Images/Internalmessage/49785567/1689934688057.jpg
I was thinking numbers on back plate will help to decern which grade this is.
Thanks for taking the time to respond Tom.
I always look at the balance (I know you know this @Nucejoe )- the glucydur balance as used in Top and Chronometer grades, have curved spokes, as on the right in the pic.  The nickel balance (used in Standard, Elabore grades) has the straight spokes.
Other than that, I don't know.
From what I've read, all the differences are balance, shock jewels, pallet and escape wheel. So you need to see the balance.
Edited by mikepilk
Thanks Mike, Thanks Tom .
Yes,  balance covered by the sticker raised my doubts, whats just as bad is that this site deletes requests for voice recording, a recoring of the tic ing sound would helped. I am going to pass on this one.
Rgds
Rgds
Bless you with five more kids ?  Do you actually have children Joe 🤣
out of curiosity how do you know it comes in those four different grades?
The reason I ask is to look up the movement I get a link like this
https://calibercorner.com/eta-caliber-2825-2/
now the problem with the link above is this movement appears to only be found in Swatch group movements. That brings up the problem of it probably isn't out in the wild and it probably only comes in configurations for Swatch group in other words it wouldn't come in all four grades that you indicate it probably came in 2 grades neither one of which you can look at and tell the difference. Oh and if you look at the above link it tells you the balance jewel protection system
now it is based on 2824-2 for which I can attach a file the manufacturing information. This is where you get all the technical specifications of the various movements. Where you will see this movement comes in four grades.
let's look at the differences for the Standard Elaboré looking through the list which isn't as nice as nice of all of them are together it makes it easier to compare but still balance protection system Etachocs.  Pallet jewels you get this Polyruby, epilame–coated.  balance wheel will be the most visible you get this Nickel gilt in other words is white colored easy to spot. Then you have differences like they hairspring but you can't visually see that I've even occasionally seen were mainsprings are different for the different grades but you can't see that either
now for the Top Chronomètre  balance protection system of course different it's Incabloc. pallet jewels Red ruby, epilame–coated. Balance wheel of course visually a pretty gold color Glucydur gilt, blind holes. then basically the difference between these two top grades are whether one gets chronometer certified or not they're basically identical somebody has to take the time to tweak it and then they send it off to get chronometer certified. So otherwise they're basically identical.
Also while you're looking at the manufacturing sheet notice the interesting descriptions of balance staff for instance Epilame–coated, flat ends. For all those people who like to aggressively polish their pivots the ends are supposed to be flattish and their epilam coded to keep the oil from running down the staff. Which you never see mentioned in the technical sheets.
oh and back to the original question what makes you think the 2825 comes in four grades? I do according to Swatch group it only comes into grades here's the easy way to show you timing specifications complements of Swatch group
ETA 2824-2 - Manufacturing Information.pdf
Ha ha,  Ya two sons, first of American mother and the second Iranian mother, as in ( eye rain ian) as some American pronounce it.
I know   ?! ?!     I  done made a mess to prove my stupidity.
I got the basic tools to prove more stupidity though.
So @JohnR725  is the only way to tell  which one we have, analyse-ing  timegrapher output?
Back to Seiko LM for me.
Bless ya Joe not stupidity mate, you do what you do because it feels right at the time.  I've  got two kids and wouldn't be without em or change em for the world. Haha yar I'm 56 and mine still works perfectly as well just ask my missus, just adapted so as not to produce any more rugrats 🤣
I suppose technically this gets complicated. For instance Seiko almost any Seiko you can bring it to the shop where work and he will charge a fee just under $100 varies between the watch he will regulate it to chronometer timekeeping. So on the timing machine it will look really good but you know that chronometer specifications aren't necessarily measured on a timing machine. But still he'll regulate the Seiko is down the really close so they look really nice on the timing machine it still doesn't make the watch a chronometer.
So by theory yes on the timing machine it should look better if it's chronometer grade. except your caliber only comes into grades and they're not chronometer.
Suppose you weren't getting a chronometer grade watch from the brand you indicate you should get one of these Heather was chronometer grade watches are supposed to come with chronometer grade certification like this then I really have studied the pictures on the link above does look like you have a certificate. I guess it all really comes down to do you trust the seller or not and if you don't like it could just send it back.
now just a reminder Swatch group is paranoid over who gives out there documentation which is why they market with watermarks and other security features because? So this means if somebody did have access the best you're going to get is them to snip out things for you. So for instance the manufacturing information for the 2825-2 is similar to the other documents that you can find out in the wild there is only two grades which are Standard Elaboré no chronometer grade. Now the various brands themselves conceivably of change stuff like how the watches regulated.
so for instance if you had but you don't manufacturing information he would find out two grades and their timing specification
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
    • I visited this place last year just before they closed their counter service - amazing shop (filled from floor to ceiling!) and the guy that was working there was really knowledgeable and helpful!. Their website isn't as good as Cousins but I understand that if you fill out the contact form they have stuff that isn't on the site. https://gleave.london/mineral-flat-bottom-domed/
    • As always in this game the answer is “it depends “ because the first one worked out ok doesn’t mean all will. A case could be made in a way that it would not really matter much, sounds like your first example. However a case could also be made so that only a tension armoured crystal could be used. Generally you replace like for like to maintain the integrity of the watch.   Tom
