Are Breitling hands glued to the movement, or what's going on?
For many reasons that I won't go into here, I've been dreaming about a Breitling ever since I was a kid. So, I'm constantly on the lookout for something affordable that I like and can service, restore and/or repair. I'm in no hurry, but the day when I wear a Breitling on the wrist is hopefully getting closer.
Anyway, by pure coincidence, I heard something quite alarming regarding Breitling stated on Kalle Slaap's Youtube channel (please see the video below), namely that the hands on Breitling watches tend to be damaged/deformed when you try to remove them, and that new hands must therefore oftentimes be ordered. I wonder if anyone shares this experience and if it is at all possible to get hold of original hands for Breitling watches if you are not an authorized repairer. It also makes me wonder if Breitling glues the hands to force owners to service and repair the watches through Breitling or their authorized dealers and watchmakers. Unfortunately, it is a vicious industry, so nothing surprises.
I've seen this video and also read more than a few times here and in facebook groups that Breitling chrono hands are extremely tight. Something in my memory also tells me that Breitling were bought out not so long ago, if that has anything to do with it ?
They are not glued, just tight. My everyday watch is a Breitling Aerospace (a quartz 😯). After sending it to Breitling to be serviced many times, last time it needed a service I did it myself, and the hands were not that tight.
There's a factory vid floating around showing them using a hammer seating the main chrono hand. I definitely tell customers the hand/s may deform as a part of the service. There is at least one hand removal tool available that's supposed to mitigate the issue, but I don't see it being much help (pushes on the pivot while pulling the hand).  Crazy thing is there's no need for such tight hands.
Edited by nickelsilver
So, does the problem only apply to chronograph hands or is it a general problem with Breitling hands (as indicated by Kalle Slaap)?
Well, lucky you! Did I mention that I like Breitling watches? 😉
Well, that sounds a bit reassuring, especially as I personally am not much for chronographs, if the problem is isolated to chronograph hands.
Maybe just the chrono hands , do they have a ripid flyback that could loosen them over time ? Incidentally i do have a couple of old quartz chronographs that have flung their chrono hands off.
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
