So first of all: yes, I'm a dummy. Yes, I learned my lesson.
While cleaning my Accutron I pegged out the jewel holes as usual, but realized too late there were burnished-in cap jewels on the other side and managed to get bits of pegwood trapped between the hole and cap jewels.
I was able to clean one out through the hole jewel with a sharpened oiler, but the other is not budging. I've been soaking the bridge over night in hexane, but it's no better this morning.
I'm worried about chipping the edges of the jewel hole if I keep it up. Any other suggestions on what might soften/dissolve pegwood?
A quick google for dissolving lignin suggests hot urea. If you have, or know someone who has a modern diesel, you might see if you can snag some exhaust treatment fluid, put it in a jar, and heat it up (or don't and give it longer). No idea what that would do to anything else though. Test on a comparable scrap movement plate first to make sure it won't do something unexpected.
8 hours ago, Canadianwatchmaker said:
Hello, can you post a picture. I will try to help. Thanks
Sure thing. Here are both sides on a light box.
20230531_202811.thumb.png.4895461e92b79a81658960cbf5573a0f.png20230531_202719.thumb.png.bf487f93be51380875f72ba3d7f5a6eb.png
6 hours ago, RichardHarris123 said:
Basically p#ss, so you know what to do now
Sadly no help on the jewels. I feel a lot better, though.
Perhaps the enzymes from modern liquid laundry detergent may eat away at the wood fibers? No scientific basis for this idea other than it is a new old plumbers trick for 'dissolving' toilet paper (also wood fibers) in blocked sewer pipes. It's worth a try as it should be fairly benign as far as the jewels and metal(s) go, I assume there is no shellac we need to worry about on the affected components? Even if it partially works it may loosen the fibers up enough to remove them?
Edited by Waggy
Has to be a joke there about p#ss and losing wood....🤣
  • Confused 1
I'm sure that these settings are able to be taken apart, but I've never done it. I think you would press out the pair cap/hole jewel, then they are two separate pieces, each jewel in its setting. I have a 218 here for service but it's my mom's and don't really want to experiment on it... haha. But maybe I'll give it a go.
Edit- it's one setting, you push the hole jewel and it pushes out the cap.
Edited by nickelsilver
One of my favourite things - Caustic soda (sodium hydroxide) dissolves most organic things. According to Wiki :
Sodium hydroxide is also widely used in pulping of wood for making paper or regenerated fibers.
I appreciate you taking one for the team! I've got a Horia-style tool at home, so I'll try it out after work tonight.
Thanks to everyone for the suggestions. Even you, @RichardHarris123😉
This was actually going to be my next try. Since I own a brewery, I have a scary amount of concentrated sodium hydroxide on hand. My only concern was whether it would attack the soft brass. A few moments of research says it reacts with copper alloys, so I'm inclined to avoid it.
22 minutes ago, spectre6000 said:
Need more info. I've got a small batch imperial stout I'm about to bottle!
Oooo! PM me or start a thread in an off-topic forum. I'm always excited to talk shop!
I've been brewing since 2008, professionally since 2015 when I opened Man Skirt Brewing here in Hackettstown, NJ. I've been toying with the idea of floating a watch meetup here, but I doubt we've got enough local folks on the forum.
Ok, I've always wondered about the skirt part.
Sounds like an end shake issue.
Do you wear skirts on the weekend?
Here's hoping I don't have to do that again. Thanks, @nickelsilverfor testing the theory out.
When I can get away with it, but usually just at work 🙂
Well, this is the most frustrating gear train I've ever tried to install.
I just spent an hour trying to get all 4 pivots to line up and I'm no closer to it than I was an hour ago.
I had to give up before firing the thing out a window.
I genuinely have no idea how I'll be able to do this.
EDIT: Guess who just figured out he also has pegwood stuck in the bottom jewels in the mainplate? BIG SIGH
Edited by ManSkirtBrew
Accutron train bridges are very easy to assemble because the jewel holes have something like a funnel to guide the pivots in. Just put the the bottom pivots into the bottom holes, gently drop the top plate on and tap the holder. The plate will just drop in. It's really satisfying.
I suspect it's because your bottom holes have pegwood in them that you can't get the plate on.
I'm sure your local Red Bar chapter would love to have you host an event.
5 hours ago, HectorLooi said:
Accutron train bridges are very easy to assemble because the jewel holes have something like a funnel to guide the pivots in....I suspect it's because your bottom holes have pegwood in them that you can't get the plate on.
One of them did, and I fixed it, and I just spent the last 20 minutes trying again to no avail. So if it's supposed to be easy, I'm clearly doing something wrong, because I feel pretty stupid right now.
The index wheel is the one giving me the most fits. It and the 3rd wheel are very tippy, and proving extremely difficult to get the pivots in the funnel, let alone the jewel holes.
I'll get it eventually. I'm just too frustrated right now. I've never had this much trouble with a bridge.
Okay friends, thank you again for the encouragement and help. I went back with a fresh head tonight and the bridge fell into place in just a few minutes.
WHEW! Now it's time to phase. The scary part!
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness oil in-between . You want a short answer now,  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
    • Yes, it looks much better, but at this point the main thing is to make the spring in one plain. so picture from side will show this better. Now it is seen that #1 bending is needed, which is normal.
