Cleaning material
By Hawaiikook808 · Posted
Thanks, OH! I agree with you. I'm currently looking at them under magnification, and they are consistent in shape and form for each section (flat pushers, pump pushers, concave, reamers, etc.). Though, a few are in bad condition and need to be replaced. Before I cancel the return I have already initiated on eBay, can any of our members check to see if there are inconsistencies in markings on their sets? Also, I have included a snapshot of the bottom of one of the pump pushers, which are very unique in shape. Can someone tell me if the bottoms of their pump pushers match this photo? I'm hoping that Seitz had some inconsistencies in manufacturing over the years regarding markings. Crossing my fingers. I appreciate you guys. Frank -
All I can say is the set I used was quite old and belonged to my master and it was complete the parts were numbered. What you might have are cheap replacements could be made in the likes of China who make cheep crap.
You have a rocking bar set and wind design chief, still usable for identification. We just need the plate diameter now. -
Thanks Geotex, From what I can see the keyless works on mine is completely different to those in the photo, I had a bit of a Google and it looks like it's called a rocking bar?? I can't seem to find a single match online though. As far as the setting lever screw goes, you've just explained what I'm doing wrong and why it was probably left out in the first place. It needs to go in before the bridge 🙃. That's why the hole isn't big enough because it's designed to be smaller to stop the screw falling out until the bridge is removed. Thank you for that! I'll remove the bridge tonight and get it refit.
