I would be most grateful if those in the know would educate me on the subject of barrel arbor holders. ๐Ÿ™‚
How is a barrel arbor holder different from a pin vice? Is using a pin vice to hold a barrel arbor frowned upon? If one were to purchase a barrel arbor holder, what is the most common size for working on wrist watches? Are there cost effective options out there? All I seem to see are pricey options from Bergeon.
Thanks!!
I have a ร˜1.50mm Bergeon arbor holder and I absolutely love it.
The 1.5mm size seems to be a decent fit for most normally-sized movements, but would probably be too large for a lady's movement and too small for a large pocket watch. I asked Alex at the Watch Repair Tutorials YT channel what size he would recommend and he replied: "The size I use almost at the time is the 150.", so that's why I decided to get the same size.ย Here's the video where he's using itย and you'll find Alexs' reply if you look for it in the comments section.
The arbor holder is much easier to clamp onto and release from the arbor (look at the picture). Also, it dramatically improves seeing what you're actually doing while removing and fitting the arbor from and into the inner coil of the mainspring. The head of the pin vice is most of the time so large it covers the entire arbor - and more - making it quite difficult to see what's going on.
Absolutely not! It's just a whole lot less convenient in my opinion.
None that I'm aware of I'm afraid, but we have some experts on Chinese watch tools on the forum so hopefully they can shim in!?
Edited by VWatchie
  • Thanks 4
Let me add the fact that the claws of a pin vice are more โ€žaggressiveโ€œ compared to that of an arbor holder. Thatโ€˜s important when dealing with polished pivots.
Edited by Kalanag
  • Thanks 2
Absolutely pinvises especially cheap ones are rough as hell inside and can easily scratch up a polished arbor.
I always used to worry about that before I got my arbor holder. With the arbor holder, I never saw the slightest dent och scratch on the arbor even after having pinched it very hard.
Just bought this PinVice; 0 - 1.5mm. It has two bits, one with internal rounded fingers and the other bit has the edged fingers.
https://www.cousinsuk.com/product/single-ended-round-with-2-collets-horotec?code=P58276
So far I've only been using it to hold a 2824-2 winding stem. Seems nicely made, works well and you get "two" for the price of ยฃ8.50 excl. VAT.
Depending on your location, members Waggy suggestion seems price-wise okay. However if you live in the economic suicidal European union, by the time I get it in my hands (due to duties and registration fees) it cost me over $34 .......
That's the reason for me buying the Horrortec ๐Ÿ˜‚
ย
Edited by Endeavor
It was just a warning regarding the cheap ones that use a collar to tighten the jaws. The design looks similar to the Bergeon arbor vice they are really rough inside the jaws. The jaws aren't curved to hold the arbor snuggly and only grip at 4 sharp points. I was actually in the middle of stripping loads of barrels when i noticed the question so i thought a real time test was in order ๐Ÿ™‚ . Under magnification there was definitely some scratching up after some rough newbie impersonating ๐Ÿ˜†
I use the pin vises on stubborn arbor/spring combos, but it's very difficult to see what you're doing, especially on small arbors.ย  I will be getting an arbor holder to rectify this--especially now that I hear good things about them.
10 hours ago, LittleWatchShop said:
Damn this forum!!ย  Another tool to put in the Shopping Cart.
I second that..... there is now one in my shopping cart too!
Is the consensus that 1.5mm is the most versatile?
I just re-thought this and looked again at my Horotec pin vices:
I'll follow @Endeavorlead and use the rounded side (above) and see how that goes, maybe try on a few scrap components to see how badly they get beaten up (or not)
Just as a bit of fun I think we should start a new grading system for tools.... based upon the frequency you estimate you would need to use them:
for example:
  • Screwdrivers you use on 100 out of 100 watches, so would be a 100% tool
  • Staking set 5 in 100 watches, so would be a 5% tool
  • Seitz jeweling tool 1 in 100 watches, so would be a 1% tool
Then we could start a new thread: What <1% Tool Can I not Live Without Next??
๐Ÿคฃ
ย
Edited by Waggy
typo
  • Haha 2
If you just grade on the frequency used, some tools will drop off the list. Some tools are (very) seldom used, but when you need such a tool, it's extremely handy to have them. To think of a balance-poising tool, a truing caliper, a Jacot tool and for more examples, I have to dive in my cupboard, remove all the cobwebs and see what else I have ๐Ÿ˜‚
Edited by Endeavor
  • Haha 2
@RickTockThis is an excellent topic and thank you for posting it. It has answered a number of questions I have hadโ€ฆand more tools I might want to get sooner rather than later. All I have is a cheap pin vise, so seeing and hearing the differences between the pin vise vs barrel arbor holder is good to note and informative.ย
ย
as always, this forums members are so helpful with all their knowledge.ย
On 5/25/2023 at 7:54 AM, kd8tzc said:
@RickTock
...this forums members are so helpful with all their knowledge.ย
Indeed!
22 hours ago, Tore said:
These are super. With brass or bronse jaws.
Those look very interesting (and vintage)! Love the brass/bronze construction -- softer than barrel arbor makes good sense. Kind of a long shot given how old these look, but any idea where these may be obtained?
I bought it (with some other tools) from a retired watchmaker. I didnt know the the real purpose with these in the first. Now i cant work without these. One for pocketwatch arbors, and one for wristwatches.
Are these also called sliding pin vices? I got mine from Cousins for ยฃ3.50, but needed to refashion the last 5mm of the jaws from 90 degree sharp corners by removing 0.5mm at a 45 degree angle. The gripping surfaces are therefore flat (not ideal but better than sharp corners). The "cutting" was done with a fine diamond file. Spreading the jaws out was done with a shard of hardwood. The hardest part was holding the workpiece. I'm a novice watch butcher, so please feel to ridicule.ย
No, these are specific tools (having a slider though), but it's definitely not the only tool that can be used to handle mainspring barrel arbors, but perhaps the most convenient (and most expensive ๐Ÿ˜ฎ).
And, congrats on making your own arbor holder tool!ย ๐Ÿ‘
Edited by VWatchie
Good tip Doc. I did something similar to mine to reduce its holding aggressiveness by running a round file inside the jaws. A small round burr will make short work of shaping the jaws also.ย
ย
ย
I have one of these - excellent pin vice and worth the money. I rarely use it on barrel arbors -ย  I find stout tweezers usually do the job
Indeed, there are many ways to skin a cat! Personally, I find the Bergeon's arbor holder to be the most convenient. Like changing from walking to cycling. Especially when it's a tight fit.
Edited by VWatchie
I find my Bergeon Mk3 Cat Skinner an essential toolย ๐Ÿคฃ
  • Haha 2
    • Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway ๐Ÿ™‚ No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko.
    • My kid woke me up at 2:00 a.m. I couldn't get back to sleep so I decided to go to the workbench. I was to tired to work on a watch so I decided to dress up tweezers and screwdrivers while having a drink and listening to some music. ย  ย  Luckily I got a comforting nap after lunch and started working on this beautiful Raketa Big Zero. ย
    • Good shout - I'll grab something like that and some around the required size from cousins too...
    • Hi, I have a lot of experience with Seiko and you can make all of those run within a few seconds a day with small adjustments to the Etachron regulator. You just need a timegrapher, an Etachron adjusting tool and ideally a stereo microscope, along with a bit of knowledge and patience. Not difficult at all for a watchmaker professional or a hobbyist like myself.
    • Courtesy of my parents who are at the Henry Ford Museum (formerly Greenfield Village) in Dearborn, Michigan today - a photo of the watchmaker's bench setup in Thomas Edison's Menlo Park laboratory. This is a pretty good display, a pallet warmer, truing caliper, staking set (unfortunately closed box), spirit lamp, and check out that six jaw chuck on the lathe. The museum is a mostly an outdoor village where Ford had moved numerous buildings important to himself and to the history of technology in the USA. (Also includes the Wright brothers' bicycle shop for example). As a teenager I worked in an 1850's tavern there. There are several other large lathes too.
