Hi, tryin to clean up my grandfathers watch
By rjenkinsgb · Posted
Again, EDTA solution as I mentioned above, or Evaporust. They attack oxides but not good metal. After some hours, all the rust should have gone. -
By Sebastiaan · Posted
Thank you for the reading material -
By watchweasol · Posted
Hi one assumes by the addition of the pictures you have the technical sheet for this watch. As mentioned by @HectorLooi center wheel canon pinion .take it down again and install only the parts required to set the hacking and turn the hands checking at each stage for correct operation. -
Hi if it is a Swiss made watch badged by ingersoll (eubauches) ther is likely a makers mark and number under the balance that may help . If you open it up and post a picture of the movement plus Any numbers.
