Help Identifying This Vintage Watch
Hello,
Hoping to get some help identifying this watch. This was my wife's grandmother's watch, which most likely she received from someone as a gift (she was a gynecologist and people tend to get really excited about giving birth and want to present their delivering doctor with all sorts of gifts). It was in a pretty bad shape and not running. The face of it is pretty scratched up and I can't make out the name of the brand. I can possible make out something like "CRE 17 Rubis" on it. The bridge inside says "Swiss Made 17 jewels".
I am hoping to try to restore it as I didn't notice anything wrong with except it was pretty dirty. So hopefully, it just needs some cleaning and lubrication. This is my first restore/repair job, so wish me good luck 🙂
image.thumb.png.d8b0331e898ee9f6332970267541dcd1.pngimage.thumb.png.06928f445f5356a9c14b8ef46910cab2.pngimage.thumb.png.1377a81671a7ea44e308515e6c53f1eb.pngimage.thumb.png.74803ad3762f1d41dcca3587a5a7f1ee.png
28 minutes ago, 0812 said:
Thank you. I did take a bunch of pics in the process of disassembly. So here are a few. I didn't see any other inscriptions anywhere else except "AV41".  Thank you!
image.thumb.png.514baab721abfd4ad99f9a3d4570ef5c.png image.thumb.png.2fa86e711c36f2eeb9eb26475cb6745d.pngimage.thumb.png.e20543840453f36a98ac0cdf235d8b9c.pngimage.thumb.png.ee8c3a1f3f37ea78932572a8c9d6935c.pngimage.thumb.png.b9825dccdb4bcee4b580698821c7a5b2.pngimage.thumb.png.dcb04ae09ada3bf366b0a00164680f69.pngimage.thumb.png.0821700c7ac417639239b468e2e25213.pngimage.thumb.png.c9b91f72a9136c8f06883e5e8f5a5402.png
Don't know the movement but the trademark is.
The check spring has snapped off.
Wow, thank you. You guys are good!
So do you suggest I change the mainspring? Is this what you mean by "Cousins"?
https://www.cousinsuk.com/search?searchTerm=GR4077
Also, "The setting lever spring on the set bridge (part #445) is broken" - which of my pictures do you see it on?
Sorry for the noob questions, I am new to this. And thanks a lot!
That's the spring you need, but you will be able to buy one in the US.
The set spring is the part arrowed below. You can see yours has broken off at the arrow.
oh wow, I see. Thank you. How would I go about looking for it? Should I look for Aurore Villeret setting lever spring on the set bridge part #445 ?
41 minutes ago, RichardHarris123 said:
Can you make out what it says on the dial?  Please post photos when the dial is cleaned and let us know how your progress.
I can't unfortunately. Any recommendations on how to clean it? It looks like someone tried to scratch off a layer off of it, thinking that it's dirt or rust. Very unfortunate. I used an ultrasonic cleaner and a swab with alcohol to clean it, but definitely needs more work.
25 minutes ago, RichardHarris123 said:
Not sure there's anything more you can do.  I think it says Acre 17 rubis.
These are meant to be good. Can buy cheaper options. Won't remove the scratches.
Thanks. From what I understand Ancre 17 Rubis is a generic term for "With 17 rubies". So no brand name on the dial as far as I can see.
  • 4 weeks later...
Guys, I am starting to reassemble this watch back together after receiving some of the parts that were broken. I came across this part that fell out during the the disassembly and i didn't capture where it belonged. Any ideas? image.thumb.png.17a2f601459e995ab6977e4067b12826.png
13 hours ago, Klassiker said:
That's the setting lever. It goes on the dial side and is part of the keyless works. It is held in place by a long screw with a short thread, which is fitted from the movement side.
Thank you. can you tell me where on this picture would it sit? image.thumb.png.90691a252cd9f162d125cef62e8158b1.png
  • 3 months later...
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any.
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
