I am trying to rationalize what is going on with this eta 955.112. It operates within the manufactures published specs for all tests, with the exception that when them is pulled, the internal IC consumption jumps to 75ua. I have compared this phemomenon with other movements and even put another electronics modules inside this same frame. They operate as expected. consuming under .5ua with the stem out. this rules out it being a grounding switch issue. energy is going somewhere my brain is thinking cold solder joint at ground pin? Has anybody seen this and how to corect?
Definitely have a look around ebay for Arnex pocket watches. You'll find many that are still in their gift boxes, essentially new old stock Swiss movements for very low prices.
By watchweasol · Posted
Hello and welcome to the forum it’s an addictive hobby so be prepared.. attached a little help for you to read. TZIllustratedGlossary.pdf -
Hello and welcome to the forum, don’t be shy are you just starting on the horological journey or a seasoned pro -
