Closing the barrel and barrel lid arbor hole.
We do need more photos but the spacer does seem to be behind the lip. -
Cant tell if its a lip or a section of thread. If it is lip, then i can only think that the slotted ring is spacer for the armoured crystal to push up to. There isn't much info out there about www crystals. Generally they are popped off with air compression of a sealed case. -
By Michael1962 · Posted
I was thinking that may be a thread. Would need more hotos to confirmM maybe @B1N9S can tell us whether that 'lip' goes all the way around or whether it tapers off like a thread? -
Well done Sam, you've successfully completed a tricky piece of work there 👍
