Hello everyone,
My name is William and I live in the State of Tennessee near Chattanooga in the USA. I've been a watch hobbyist since my early 30s when I was fortunate to befriend a seasoned professional watchmaker who taught me a great deal of what I know. Since I already enjoyed working on cars, motorcycles, bicycles, and many other mechanical things, watch and clock work seemed to fit in pretty well. It's a great hobby and I've found you can spend as much or as little money as you like as long as your tools are good. I have a special affinity for US and Swiss mechanical watches, the pocket and wristwatches of the Former Soviet Union, and Bulova Accutrons.
In addition to watches, I also enjoy music on vinyl, fountain pens, film cameras, and literature.
Great to meet everyone,
-William
