Had about 20 watches stolen last weekend some of which did not work as i had not had time to fettle them but the one that hurt most is they had my grandfathers gold pocket watch which had "To Bert love Mollie" inscribed on the back.If any one see,s it on their travels  let me know please.
I can think of nothing worse than being burgled, especially when sentimental family heirlooms are concerned. Apart from the gold pocket watch, is there anything else we should keep a lookout for?
Sorry to hear that, never been done myself but my parents had a visit a couple of years back. These pondlife are like magpies - anything shiny - worthless or not. As clockboy & geo have already stated please post pics - they need to move this stuff, fleabay & similar are good places to fence stolen goods. Hopefully something may turn up.
As for the rest of us - try to take pics of any valuables you own, yes I know its a pain but it can help in these situations.
Sorry I'm a bit late with my comment on this. I do hope you can manage to get these items back. Many years ago the police would visit the shop I worked in with a list of nicked goods and ask if anyone had been in to try and sell such items.
Good luck with this.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
