How to remove pressed on wheel? Specific tool?
Very best wishes to you and your family, as a carer myself I know how difficult things can be.
Tah-dah. A mini blow torch to harden it, then quench it and just a lighter held under a brass mainspring barrel that the part sits in to temper, Its important to wipe off any grease from fingerprints with ipa, you might be able to see i missed a bit at the top of the arm. Its a very satisfying process. I now just need to deal with the more difficult repairs, anybody any good at replacing rubbed in jewels ? 🙂 -
No I haven't tried that, I'm just thinking of the most complicated solutions 🤣 Another great idea 👍 All I need to do is hold that little bugger steady while I try and screw it in, without starting to shake, it gets the better of me sometimes but is getting less the more I do 😀 I need to order some bits from Cousins so I decoded to put this to one side until I get a balance screw holder, it may come in useful later on as well. I'm assuming it closes down enough as I don't know the diameter of a balance screw compared to the stud screw, I haven't worked on a movement with balance screws! I'll be getting the cheap one 😆
