Gold case restoration.
Eyup forum members, i hope you are all in good health. A bit of a random/unusual question here ( of course what else can you expect ? ) Just a thought I've had, maybe something, maybe nothing, maybe stupid.  But if i dont ask i won't know. Probably directed towards good case restorers. Gold case back engraving, the retirement watch sort of thing. There are plenty of nice gold watches out there but many have back engraving some with quite deep inscriptions. These tend to be cheaper than a non marked back. Seems a shame to lose that history but not all of us want to know what year Bernard Cratchet retired from East Scunthorpe sewerage works and that his colleagues will sorely miss his rendition of Dan Dan the lavatory man. So my question is this- can the engraving be filled and buffed, rather than just ground and polished as some engraving can mean losing quite a lot of material to remove it. If anyone has tried this can the inscription still be visible through the gold fill ? Thanks in advance peoples.
15 minutes ago, oldhippy said:
If the filling is done correctly you shouldn't be able to see  what it previously looked like. It will be expensive so you need to ask yourself is it worth it. My own feelings is it is part of its history and should be left.
Appreciate that OH, i personally like to keep things original as far as possible but it would feel like it still belonged to someone else.
I'm in two minds. If it increases the resale value, or you want it to be your watch, then it might be a good if not expensive thing to persue.
But then again, perhaps in 10-15 years Scotland Yard might announce that they've finally uncovered the identity of the infamous East Scunthorpe Sewerage Strangler, and suddenly your old retirement watch is worth a mint to some weirdo.
The problem with history on the back of your watch is for a lot of people it decreases the value considerably. On the other hand a lot of the engravings are very stylishly done and to me it's part of the decoration it's not really an issue. But is the decreasing in value that upsets people.
3 hours ago, dadistic said:
I think it might be tricky to match the gold.
That's the problem that I'd be concerned with. Gold tends to have color variations. I've seen were somebody had a case replayed it for instance and to me it didn't look right bigger just didn't look like the right shade of gold.
Then depending upon the case back it may be expensive in that if the case back is smooth you can just fill it in with whatever slaughter you have but solder tends to not necessarily be the same carrot as the original gold because it does have to melt. So you fill it all in polish it backed ounces nice and smooth and possibly replace the entire case just so it all matches.
But if you want to find out find somebody who does engraving and ask them how to deal with it. The reason he ask existing people who do engraving is accidents happen and they have to be fixed. This is where a lot of modern engraving is better than the vintage because the modern engraving tends to not be as deep somebody hand engraved in the traditional way it can be a really deep into a case back. Versus something newer that if it's solid gold or silver can just be polished out re-engraved if you so desire.
Good point lexacat👍  I'll check the news reels for that area before i make a decision.
28 minutes ago, grsnovi said:
What sort of watch is it? Is it one for which you can find an "original" donor case? Or, a donor replacement back?
Just something I'm looking at buying G. The engraving is quite deep and to dress it out would remove quite a lot of gold and maybe leave the back too thin. I even wondered if the engraving could be partially reduced and the gold removed  be used to fill the remainder. It would seem a shame to take away its history but its up for sale, wasn't wanted and the inscription doesn't actually have meaning or sentiment any more. It wouldnt be connected to me or mine as such and not something i could pass down to my children. Still thinking 🤔
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
