I have an old pocket watch, and the sideshake on the arbor is unacceptably large.  The amount of shake is just visible to the naked eye, so I am trying to close it up.  I am using the method prescribed by Kalle Slaap at Chronoglide Watchmaking
So I tried it, with gentle tapping at he does, and it did not make any noticeable change.  I kept having to hit harder and harder, and I'm eventually wailing on the staking punch to try to get it to do anything.  I had to hit so hard that the equipment on my table was rattling, and it was barely making a dent in the movement plate.  In the YouTube video, he closes the hole to the point where it's too small, then broaches it open.  Mine never got close to the point of being too small.
The dial plate took to the staking set better than the movement plate.  If you look in this video that I took, the sideshake on the movement plate is still large enough to be visible.  What methods do you all use to close up holes?
1 hour ago, Paul80 said:
Hi.
I suppose the obvious first question is are you using the correct or most appropriate punches, You are using domed punches ?
Correct, yes.
The larger the diameter of your punch the higher the force needed to perform noticable work.  Not knowing what the base material is it's hard to say how much force will be required to displace it.  If things on your bench are jumping up and down, your bench may not be ridgid enough for this type of work.  If your bench is solid enough nothing else should move.  Try putting the staking set directly over the bench leg (it should have better support there) and you may have better results (just don't hit it as hard as you have been until you know that you still need to).
Best of luck.
Shane
Thank you both for the replies. I remembered that I had one of the hole-closing attachments for my Seitz tool. So this gave me an excuse to finally restore my Seitz press.
I pressed down on the hole with the correct attachment and in a few minutes the hole was closed up a little further than needed, do I broached it open a tad and we're all set!
I thought the funniest joke in our business was "Never use force. Get a bigger hammer", until @nickelsilvermentioned that there are situations where a bigger hammer really is needed. I can't remember the context right now but thought it might be a good idea in this case!? Anyway, I have never closed an arbor bearing so don't take my word for it.
That’s great you managed to solve it!
Could you take a photo of the hole-closing attachment? I’m curious how a lever jeweling tool could close a hole where a staking tool didn’t.
On a brass plate it only takes light taps with a small hammer to close the hole.
Your "wailing on the staking punch " had me worried 😧
Glad you sorted it, another lesson learned
I'd be very interested too, so, please!
I hadn't realised until I just looked, my jewelling tool has hole closing bits.
I don't know whether you are supposed to just press the lever, or hammer on the top ?
  • Thanks 2
That’s an interesting “pusher” for hole closing. Do you use a flat faced anvil at the bottom? I’m also curious if just using the lever will generate enough force to deform the brass plate, or do you use the spindle (with hole closing punch inserted) with a hammer like in a staking set.
Edited by ifibrin
6 minutes ago, GregG said:
Mike's already beat me to it, but these are the ones I bought.
https://www.cousinsuk.com/product/seitz-jewelling-reducing-jewel-hole-tools?code=J30577
I use it with the regular jewel press, no hammer involved.  The lever will give you a huge mechanical advantage.
What did you use to support the movement from the bottom? A flat faced anvil? Or a normal anvil with hole. Do you think you could take a picture of the set of anvil and hole reducing pusher you used to successfully close the hole?
Edited by ifibrin
I didn't have an anvil large enough to support the large plate, so I used the "face plate with 3 clamps" body from the Seitz catalog, page 19 (https://ihc185.infopop.cc/helphand/pdf/seitz.pdf).
I can take a picture when I'm back home later if you'd like, but there's not a whole lot to see. 😛  Just imagine the hole reducer punch with the face plate on the bottom.
Edited by GregG
In the Seitz catalogue it shows them used with a flat anvil at the bottom, and the lever to create the force.
These are designed for slightly loose jewels, so only a very slight movement of metal is required. For an arbor slopping around in a bridge, I will still be using two round punches (top and bottom) in my staking set. And a hammer 🔨 -  it's "hammer-time" (ref Kalle Slaap)!
This way you will enlarge the vertical play of the arbor, too. Not something that you really want.
Disregarding that the non-butcher method is to replace the worn hole with a bushing.
Frank
Frank
If you are careful I don't think this is so. If you only deform a little at the edge of the hole, the 'shoulder' on the top of the arbor is wide enough to press on the flat surface of the bridge.
I closed a hole in a barrel bridge this afternoon, and just put it under the microscope to check that the vertical play is not affected.
And for the movement I'm working on, the bridge is far too thin to bush - at least for my tools/experience.
Edited by mikepilk
Frank
How would be just closing up the arbor hole from just the top face Frank leaving the underside flat so the endshake remains the same.
This is how I would do it (if not too much worn).
Frank
Actually, I would be interested in some photos of the faceplate, especially on how to hold pieces (such as a mainplate) where it’s not entirely flat along the entire circumference. How do you keep the hole you are inserting perpendicular to the axis on a faceplate?
That's how I did it until I saw Kalle Slaap's video. As @ifibrinpoints out, if the plate isn't flat, it can be difficult to sit it on a flat stump, and get the punch exactly centred.  I had this problem and ended up with the created chamfer not being symmetrical.
Using the two punches makes it much easier to get the plate and punches perpendicular, and the punches centred in the hole.  As @praezis points out, there is a danger of increasing vertical play, but this shouldn't usually be a problem. The pic shows one I just did, with the chamfer arrowed, being much less than the width of the arbor shoulder.
Also a question of the dome radius.
A high domed punch will leave a small chamfer but rather push the metal aside. A lower domed one will push the metal more down and close the hole, but produce a wider chamfer.
A bit dangerous just with those narrow shoulders of barrel arbors, where all support is needed to avoid digging into the brass.
I admitted that I do this, too, to avoid higher cost and prolong the period until a "real" repair will be done. But this punching is just a short term, not lasting repair.
Frank
Thanks Mike. Good hear someone elses experiences and get overs .
Choosing the right sized punch with a balance of leaving enough of the mainplate untouched but not so small that the new created arbor hole is too thin. Learning to bush a hole woukd be the next step forward. Appreciate that information Mike.
Frank
A fine balance then Frank and a temporary fix. Second stage of wear occuring much faster than the first stage.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
    • For years I've done it the el-cheapo way (read: cleaning by hand). Bought a 2nd Elma S15(H) ultra-sonic, including proper cleaning-fluids (Elma WF Pro (cleaning) & Elma Suprol Pro (rinse)) and entered a complete different cleaning world. These cleaning fluids are none-water based and not that easy to obtain. Initially I bought these fluids in Germany "SKSONIC" (www.sksonic.de) but last year they stopped shipping international. Perhaps they resumed international shipping? You can always ask them. You could also ask @VWatchie, he lives "next-door". As for the fumes; I use the ultra-sonic in my garage, partly for the fumes, but more for our dog ...... he goes "bananas" when I switch on the ultra-sonic. Oh, next on your list (if you consider watch-repair as a long-time hobby), a Microscope (up to 50x is enough).  Pegwood leaves, observed under the microscope that is, whole tree-trunks behind 🫣 Ultra-sonic, in combination with proper cleaning fluids, takes care of the cleaning.
