Vitascope Clock Repair/Upgrade
MM4D
Hi.
I've recently been given my grandmother's Vitascope clock.
It's in working order, but I think it might benefit from having the insides cleaned, moving parts lubricated and a new power cable added.
These are all things I am capable of doing, but before I jump right in there I wondered if anyone here had any experience of these things?
What sort of cable should I use for the power supply, what sort of lubrication would be suitable?
Any thoughts, hints, tips, tricks and advice would be gratefully received.
Images of the clock.
There is some damage to the coloured cylinder, we think due to someone putting a bulb of to high a wattage in there at some point. But I'm not looking to fully restore, just clean and repair.
Some of the soldered wire connections on the switch are now loose too.
I've read about people replacing the power cable with a 3 core earthed cable, but I'm not sure where I would attach the earth. I presume to the metal frame some how.
Hi Definitley in need of a good clean and as OH mentioned grease rather than oil on the gears, oil on the pivots.
https://r.search.yahoo.com/_ylt=AwrIQZH4xFJjUQYAlQB3Bwx.;_ylu=Y29sbwMEcG9zAzYEdnRpZAMEc2VjA3Ny/RV=2/RE=1666397561/RO=10/RU=https%3a%2f%2fwww.davewestclocks.co.uk%2fClockrepairs%2frepairing.a.vitascope.clock.htm/RK=2/RS=Y8eYLvU4HYLJYTF6Y5ni1NydhUY-
A look at this liknk Davewestclocks  you will find useful information
  • 6 months later...
  • 8 months later...
Had one in the family since the 40's, Motor burnt out around 1980, had an RAAF instrument maker, now deceased, repair it.
   I reassembled it, the colour wheel disintegrated, from lamp heat, small plunge coffee container fits the bill! Paint used was from hobby store, for spraying on glass. Now have fitted LED bulb, like stovelight, all goes well!
  The original wiring on thus clock, did have 3 strand, with the earthwire attaching to thechassis, would suggest surge protection type plug, as I think a lightening event could have caused the motor burnout. Cheers John
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
