French clock
Willow
Hi everyone, hope you are all well.I am having problem with this French clock as soon as i put the pallets into the pivot where this adjusting screw is, sorry don't know the name of this part the train will not turn, i found this out after starting with the barrel and working up the train to the pallets if someone has turned this screw and i hasten to add it wasn't  me,would this be the cause of the problem and how do i go about rectifying this.
Thank you.
Hi Willow  as you look at the screw there is a slot in the back plate align the screw slot with this and then try again. normally these screws are factory set and do not need adjusting as the depth is set up. If some one has turned it it begs the question ,why,  the "Brocot" escapement is usually very good unless its been worked on by some one.  You have basically to reset the depth on the lockings on the pallet, check the pallet surfaces are not worn or chipped and highly polished (mirror finish). Fit the pallet anchor assembly and wit a couple of turns on the spring check the action and adjust untill it locks and unlocks then try the clock for running. Might take a bit of time going bit by bit.  all the best
Hi willow, just be careful when moving the adjuster they are usually very tight primarily because they are factory,  set use a good well fitting screwdriver to avoid slippage. As you see the screw adjuster is circular and the bearing is on the side any adjustment will go up/down in an arc. If as we suspect its been moved the lateral and vertical positions have been compromised. put a small dot in the position it is now and when refitted check the action and adjust accordingly.   all the best.
Hi willow  have a look at this bit of reading might be of some help.
https://r.search.yahoo.com/_ylt=AwrIAX8ZKx9jqRAApUF3Bwx.;_ylu=Y29sbwMEcG9zAzYEdnRpZAMEc2VjA3Ny/RV=2/RE=1663015834/RO=10/RU=http%3a%2f%2fwww.abbeyclock.com%2faeb7.html/RK=2/RS=jZ9ZEnYKNW2O2x8OI7jRBYPbnOU-
Thanks for that watchweasol great bit of information pallets unlocking now, clock running just needs a bit of adjusting as it stops after  5 mins but making progress .
If it is stopping because of the escapement check all the pivot holes for the escapement, pivots and burr on the escape wheel and the angle  of escapement the pallets also need to be smooth with no marks or signs of wear. I can't tell by the photos but many clocks with this type of escapement the crutch is friction tight, so it has to be tight enough for it to work, too lose and it will stop, to tight and it won't set its self in beat.
Hi willow   with it being a deadbeat(Graham) escapement (no recoil) it has to be right, The diagnostic path as laid down by Old Hippy has to be followed and all points checked. A recoil escapement gets a bit of help from the recoil and can overcome little problems like slightly out of beat or locking. Its a question of patience and dilligence.   all rhe best
Hi oldhippy, the crutch on this clock screws on and off, away at the moment will check when i get back thanks.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
