Hello Folks! It's been sometime since I last posted anything had to take a long break from watch making. Was given this old pocket watch and I was surprised that it wound and run at all since after taking a closes look at it and seeing how gunk up it was. So far I not ID it 100% but when I first seen it was thinking it was a old Waltham. I did some digging but did not find much on Langendorf watches other than Langendorf is the name of a town in Switzerland and that company was the biggest maker of Swiss movements in its day. So what I found on the watch was Steward 15 jewels Langendorf W CO. Swiss on the motion side and on Keyless side 833930 which would be a  serial number I'm guessing  but so far not no sure. As always thanks for any help.
Cheer! Paul
Hi Paul,
It would help to know the diameter. There are approximately 90 variations of Langendorf calibers shown on Dr. Ranfft's web site. Knowing the diameter and any numbers would help narrow the search. You should be able to match both your dial side and train side images to one of the watch movements shown there. Type "Langendorf" into the search box.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&2&2uswk
Edited by grsnovi
forgot to add link to ranfft
I have look there but did not see this calibers unless I miss it and that page only listed one open face watch and that's not this one also don't see any with this type of keyless works. Anyways  this is a open face pocket watch and the OD is 39 mm and the only number found was what was in my first post which is 833930 also this has the split winding stem. I did find one like it case and dial looks about the same and the motion side looks about right bid says 6J but that's not helping much since there no 6J showing on the  ranfft site.
https://www.ebay.com/itm/193775885740?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=193775885740&targetid=1263433206854&device=c&mktype=pla&googleloc=9010006&poi=&campaignid=16190447015&mkgroupid=128435277530&rlsatarget=pla-1263433206854&abcId=9300820&merchantid=108984430&gclid=Cj0KCQjwguGYBhDRARIsAHgRm49iBG1v8kjjLFw078lcAsaf7x_u-nBtP4MH32nhfWcRvKNqQB-ikRAaAl4CEALw_wcB
Edited by wudce
5 hours ago, watchweasol said:
Have you had a look on the "pocketwatchdatabase.com" site. If you have a maker and serial number you should be able with luck , to ID the watch.
the problem with the pocketwatch database is it's based on parts catalogs. This means typically the watches are American the company had to be big enough to actually have a parts catalog.
Won't be the first time I've had a un-id movement to work on. Parts are out of the cleaning machine and don't see anything broke or wore out had to do a per-cleaning before this it was gunk up very badly.
39 minutes ago, wudce said:
an un-id movement to work on...
Well, you know it's a Langendorf...
...just not which. I wonder if sending your images to Dr. Ranfft would help him? He must have "holes" in his database.
I don't know about Dr. Ranfft  website but I know the pocketwatch database I think you can submit pictures. The problem is there are so many unidentified watches out there
Seems like I've been down this rabbit hole before. If my memory not failing me I think I have two other here that I worked on and never knew what they was.
Moving to correct sub-forum.
Why is this happening?
Please don't be offended - from time to time, in an attempt to keep WRT organized, we need to move threads to another area more suited to the subject of that thread. Members can help the forum staff by checking for a suitable sub-forum before posting as this will help to reduce their admin workload.
    • I am puzzled by something a snipped out something from your image and what exactly disassemble tell us? my confusion is the symbol for FHF looks like image I have below year symbol as a star and righted this instant are not finding what that means? I suppose we could use the fingerprint system to verify it really is what it claimed to be. Size itself is really interesting there's almost no watches in that particular size. Then were missing details in the photograph above like diameter of movements to verify it really is the size and are missing the setting components.   went to the bestfit book looking at the symbols didn't see it. Look at the link below I did find it back to the bestfit book and yes it really is there https://reference.grail-watch.com/documents/history-of-ebauches-sa/ then bestfit book says lists the size as 10 1/2. one of the problems with vintage watches is finding parts yes a donor watch would be good.
    • Actually, this could be the issue. Drag from the module could be overcoming the cannon pinion. It was definitely not at the point that the driving wheel was loose on the cannon pinion, it took a little bit of effort to rotate it when applying the grease. Maybe I need to look again at applying oil to the pivots.    Yeah, it's very annoying. I don't want to give up on it, so back on with it over again until I catch a break.
    • The sping is not pushing directly on the cap, but is pushing against the spindle. So, even if the usual black cap is replaced with the micrometer cap, the spindle is still pushed up.
    • But he tells that the micrometer cap doesn't screw into the spindle. How can the spring push the spindle up if there's nothing to grip? There is a screw visible on top of the micrometer cap so should it be able to screw into the spindle? I'm feeling really dumb now. Does anyone manufacture that cap as an aftermarket item? Might be worth investing. Ok so the spindle is different, now I get it.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
