Diy rotary cleaning machine
By luiazazrambo · Posted
There is one Oris there at least, and if you could get a Unicorn for this price!??! 😄 It says that they don't work though, you might need to figure out what a Unicorn eats then. 😉 -
I wonder whats inside, bought it blindly, not cheap at all. -
Hello all, I had recently opened up an old Seiko from 1997 I got to change the battery, well I opened it up put the battery in and nothing works still (yes it is the right size battery). The movement looks fried and I think I need to get a whole new movement for the thing. My question is, what type of Japanese quartz movement would work for this watch? Would the one I have a picture of work?
Here's a quick Gif I made to show truing the balance using callipers. This has such a slight wobble, but is within acceptable parameters. The important thing is the balance doesn't touch or rub anything when in operation. This is an Eterna Tank. Here's a pic of the balance freshly rivetted with a new staff in the movement
By spectre6000 · Posted
I just poked an inflation calculator, and $5 in 2020 would be about $6 in 2024. Doesn't fit very neatly into any status codes, which stop at 5XX, but that's honestly somewhat arbitrary outside of a clever pun for those that dabble in such things. Back during the pandemic, I would spend a good chunk of idle time in the evenings scanning through hundreds of listings a night, and I would only land 1-2 a week max. I would often go months without finding something suitable. A very small percentage of the watches in the price range are worth pulling the trigger on for my purposes. The number floating through the thread here may be somewhat deceptive.
