Swansea Goldsmiths Carriage Clock
HectorLooi
I just received this carriage clock this afternoon. The seller said that the clock wasn't working and that the balance wheel was wobbling.
I assumed that the balance pivot was broken and should be an easy fix. I removed the escapement platform and inspected the balance pivots and true enough, the upper pivot was broken. But in addition to the broken pivot, the pallet fork is missing.
Does anyone recognize this escapement platform? The only markings on the platform are 581.380 and a logo which I don't recognize. The only marking on the rear plate is shown below.
I hope I'll be able to find a pallet fork for this platform and get the movement working again.
TIA
Still struggling to find any information on this escapement platform. It looks a bit like a gorge no. 22 but I can't be sure.
The width of the plate is 22.5 which is correct for a no. 22 but the length is only 34.5. The top of the plate appears to have been filed off. The overall height is shorter than a no. 22.
I am really hoping @oldhippy or @watchweasol have some leads as to the maker of the movement or platform.
TIA
This is a modern carriage clock. You can tell by the shape and style of the screws and the shape of the click and the click being black looking and not blued. The platform has been some what hacked about it should have four screw round hols to hold the platform (what a mess) From what I have found out it looks like  A C G is the trademark of Huber (WJ)
  • Thanks 2
  • 4 weeks later...
I managed to find a Gorge no. 4 escapement platform on eBay.
It looks correct dimensionally but the opening for the escape wheel pinion is facing sideways. There is no way the contrate wheel can engage it. Weird.
Are the clocks configured this way?
Anyway, I grabbed the tube with a smooth jaw plier and managed to turn it the correct way.
Another weird thing with this escape wheel is the pinion is tapered towards the pivot. I'll have to check if the contrate wheel can engage the pinion at the correct height when I get home tonight.
The clock came with two of the dial feet missing and no fasteners for the remaining two feet. The feet were not the usual post with a pin through it, they were just a wire with the ends flattened.
I decided to remove the remaining two dial feet and glue on some homemade screw on feet. The remaining dial feet came off with hardly any trouble. I then spot welded 1.6mm screws to pieces of stainless steel and glued them to the back of the dial. Worked out quite well actually.
I managed to fit the new escapement platform and get the clock running again this evening. But it was fraught with all sorts of problem along the way.
When I tightened the platform all the way, the escape wheel tube pressed on the contrate wheel and siezed up the gear train. The only solution was to cut away the bit of the window that was impinging on the contrate wheel.
Then when I tightened the escape wheel/pallet bridge, I noticed that the escape wheel was very tight and there was no endshake. The escape/pallet bridge was also lifted and the teeth of the escape wheel was high on the pallet jewels. So I had to push in the lower jewel. I tried pushing out the chaton holding the lower jewel in the tube but it simply refused to budge. So I decided to push out the escape tube by 0.03mm.
When I finally got enough endshake on the escape wheel, I was close to celebrating. Then when I screwed down the platform, the tube was impinging on the contrate wheel again. 🤬
So out comes everything on the platform and I cut back more of the escape tube. I'm just glad that I didn't make a pig's breakfast of the tube.
    • My mentor has been using one of the Chinese clones for several years. Seems to work very well. Just put the object you wish to demagnetize in the centre of the cross and press the button. One word of caution though, the quality and QC of Chinese clones can vary a lot. You'll never know whether you got a gem or a lemon.
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
    • Hi. First thing to do is measure your oil movement as the vx32E and the 43 look very similar but one is a couple of mill smaller the vx32E.  Also the canon pinion heights differ attached tech sheets for 7N22. And  VX43, check details on the sheets. 7N22A_29A_33A_42A_43A.pdf VX43.pdf Hattori VX32E - Specification.pdf Hattori VX32E - Disassemble.pdf
