I think it's best not to potentially get us in trouble with the copyright owner so I have removed it. But thank you anyway - i know you were just being helpful. :)
HI Mark i wasnt sure if it was still under copy sorry if i did wrong
I believe it is still under copyright :)
I am no expert but I understand that copyright in the UK is for the lifetime of the author plus 70 years. Someone correct me if I am wrong.
[emoji106]
"Duration of copyright
The 1988 Copyright, Designs and Patents Act states the duration of copyright as;
For literary, dramatic, musical or artistic works
70 years from the end of the calendar year in which the last remaining author of the work dies.
If the author is unknown, copyright will last for 70 years from end of the calendar year in which the work was created, although if it is made available to the public during that time, (by publication, authorised performance, broadcast, exhibition, etc.), then the duration will be 70 years from the end of the year that the work was first made available."
Well that's a good way to start hey  :bbq:
My next effort will be the security codes for the crown jewels (dam aussie's very uncouth)
You can just PM those to me personally. I have no issue with that :D
  • 4 weeks later...
hey guys! i am new here,and really dont have much to contribute,yet i am very interested in this subject and hope you dont mind my sitting in the corner(so to speak) and learning !?
Welcome aboard Irish. There are a lot of good people on here willing to help out when they can. It doesn't matter whether you just want to tinker, or get into the serious side of watch repair, as long as you enjoy what you are doing. I'll go and clean out the corner to make it more comfortable for you! :)
thanks for your welcome geo. and for the record i am seriously not even close to being a beginner !! but i do enjoy life and tiddling around with watches , so bare with me and maybe ill learn something !!!
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
