Hi, my name is Bruno I have a couple of wwii watches that I intend to start a cleaning and oiling process.
But I have got concerned about possible dangerous materials they could have specifically radium on dial (dial painting or numerals?) or hands.
My question is if this a real concern? Do you guys have experience about working on it? Or should I just give up on them for the best of my health.
i have an A-11 bulova (at least seems original) and an Alprosa, both supposed to be from WWII age.
Hi Bruno . I have quite  a few watches from the 30s up to the 50s that have radium lume. There are differences of opinions on this subject. Somewhere here is a chart with radioative danger levels of materials we encounter during general living. Radium lume did seem rather low in relation to what is hazardous to us and within certain guidelines of exposure.  That being said if incorrectly handled and disturbed risk would be higher. Any dust inhaled and absorption through your skin an obvious danger. The British MOD did change dials to a safer Tritium lume dial on their mil spec. watches after the second world war second as and when they were serviced . It doesnt stop me working on watches with radium but i am extra careful and do wear a face mask as a precaution.  The risks though are entirely your decision.  People can smoke heavily all through their life without any cancer scares others get away with very little. Some research on the subject will help you decide.
Have a read of our pinned topic below, and continue the discussion there.
  • jdm locked this topic
This topic is now closed to further replies.
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
