Automatic mainspring normal slippage?
Hi all - As I have acquired more automatics, I've started to wonder what normal behavior should be for a mainspring that is wound until it begins to slip. My first auto was a Vostok 2416 and if hand wound up to say, 18-20 turns, the mainspring slips audibly with that soft "twang" of unwinding the same as when placing a spring from a winder expanding into a barrel. It will then accept another 8-10 turns before it slips again, 8-10 turns, slip, etc. It runs for about 34-36hrs if wound to just before it the slip.
Knowing that automatic mainsprings had to slip in the barrel to prevent overwinding, I had just assumed it was normal to slip and unwind halfway. Other autos I've since acquired including another Vostok 2416 do not behave the same way (so it's probably not another oddball Vostok behavior). I never hear or feel a slip from an NH35, or from the other 2416. And a Chinese auto when hand wound will reach a point where the wind feels rougher, as though the bridle has started to rotate around the barrel wall without unwinding.
Does it sound like my original 2416 is not behaving as expected? Possible that insufficient or no braking grease was applied to its barrel? It's coming up on my list to attempt a service and I guess I'm trying to gauge whether I should start sourcing a new mainspring if you think it's likely something is broken in there. I have not disassembled it yet.
Hi
I have not worked on a huge amount probably under 40, and mainly Seiko and Citizen and a TAG and have never felt or heard the mainspring slip on any of them.
I got the impression when I asked about it that the slip is so gradual that it should not be detectable.
Given that I have not don't that many and am quite new at this dont take what I say as correct, await a more knowledgeable reply 😉
On Seikos the transition is very smooth because the entire system is designed for maximum efficiency. There is no sound, but you can feel the reduction in torque by holding the driver with the very tip of two fingers, and turning it slowly, exercising just the minimum force needed.
Testing on bench is just indicative. If the auto winding behaves on the wrist, as in skipping a day of wearing without the watch stopping or slowing down, then all is good in that department.
…My first auto was a Vostok 2416 and if hand wound up to say, 18-20 turns, the mainspring slips audibly with that soft "twang" of unwinding the same as when placing a spring from a winder expanding into a barrel. It will then accept another 8-10 turns before it slips again, 8-10 turns, slip, etc….
This behavior is not normal! It indicates a worn spring or bent bridle. The mainspring bridle should just slip to the next notch in the barrel wall which is 1/6 turn only.
I have this problem with my Vostok Amfibia. Originally before I  used braking grease in the barrel, it didn't have this problem. I haven't tried cleaning out the barrel and using normal grease. I should really do that and post my findings.
Interesting, thanks. It has had this behavior since it was brand new so I wonder if it's a bad spring install. I do plan to strip it probably next month and see what happens after relubricating it.
Yes, I'd be interested to hear the results.
    • The wheels turned fine. I set the escape wheel in the epoxy when it had just ‘skinned’ and wasn’t set, made sure it spun with the 4th wheel, and let it set.    After cleaning I assembled the barrel and wheel train - all fine. Moving the barrel the escape wheel spun freely. I put a bit of 9010 in my epoxy setting.    It went wrong when I put the pallet fork in. It wasn’t seated right (no jewels) and the escape wheel  knocked a pallet jewel out. I have no idea how to reset a pallet jewel - epoxy again? I’m not spending any more time on this one - it’s missing hands and the front half of the case anyway, and I have more watches ready to put on the bench.
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
