Oris 292 keyless works question
I am currently towards the end of re assembly of this Oris 292 movement. I dropped the ball on documenting the disassembly and am not sure what is actually happening underneath this cover plate circled in blue. I know that the three gears go together on the back of the plate. What I don't know is what engages with the spring circled in red and where does the other setting lever go. The gears are placed in more or less the position they need to be in for the cover plate to be installed on the last picture. Anyone know anything about this movement?
Was the watch transitioning between winding and setting before you started on it? It looks like that spring should have a part that sticks up and catches the hole in the rocking bar/bascule part. It does have to have a spring engage on it somewhere. Maybe the spring had the end broken off somehow?
I'm just guessing, as I don't know this movement. Good luck.
I have no idea. This watch was a non runner from eBay and both springs in the original plate were already destroyed (this is a new main plate that I ordered), so I don't really have that good of an idea of how it all goes together.  I assembled everything yesterday and engaged the spring with the post in the plate that holds the gears. It kinda worked but I don't think it was right. I still have no idea what to do with the other lever.
8 hours ago, Kappa505 said:
…I still have no idea what to do with the other lever.
This additional lever is definitely not used on your movement. It looks like a duplicate. The pic shows that there is just one lever in this movement (147).
The spring 15 has to set the rocking plate 14 under tension somehow.
Here you see how the longer leg of the spring is bent downwards when the plate is mounted. Obviously it pushes the right part of the plate up:
Edited by Kalanag
This is the underside of the plate with the wheels installed. As you can see it has a pin (arrowed). This fits behind the spring as shown below such that the spring pushes the pin towards the setting lever.
It's not the easiest of installs because the plate covers most of the access to the spring, however, there is just enough room (shown below) to use an oiler to wedge the spring down to create a gap between the main plate and the spring for the pin to drop in to.
It might be easier to install the keyless before the mainspring bridge.
Thanks, there must have been one installed on the replacement main plate and I didn't notice.
I tried that but the operation wasn't smooth. The crown had to have pressure in a certain direction in order to have the gears of the plate engage properly during winding. I wish I could post a video of it.
2 hours ago, Kappa505 said:
…I tried that but the operation wasn't smooth. The crown had to have pressure in a certain direction in order to have the gears of the plate engage properly during winding.
The spring should push the right side of the rocker plate up enough to bring the intermediate wheel on the left side into engagement.
I will set it up again and make a video.
The mainspring bridge is on the opposite side of the plate with this movement. I don't know that it would make a difference.
Yes Kappa. They are a  pain in the arse.  Hope this helps 😆
Sorry mate i couldn't resist. I have stripped and reassembled a few like these when i first started.  This part of the movement is bloody awkward to put back together and definitely needs some photo recall. I also got stuck at this point for a good hour trying to figure out the best way. I do seem to remember i did some reassembling of this from the dial side, possibly that return spring. If you are really stuck i will see what i have that i can strip back.
That has just jogged my memory. The pin on the back side of the  gear rocker plate fits behind the long side of the spring. This then returns the plate and gears to winding position. The arkward part is getting the spring in front of the pin. The easiest way is with the gear train removed, fit the spring after the setting and winding gears are in position then reinstall the train 👍. You've probably already figured that out by now. The other lever is a duplicate of the stem setting lever.
Edited by Neverenoughwatches
Ok I have reassembled this part. It still doesn't feel right. Here is a video of the keyless works in action. I also believe the hairspring on the balance isn't concentric. I guess I will be reviewing marcs course on how to address this situation.
Here is a short of the balance in action on the old main plate.
https://youtu.be/3z4uDOxqutU
7 minutes ago, Kappa505 said:
It feels both tight and rough.
If you look at the photo that @Marc posted above, the 3 wheels should have the bevelled teeth facing up. Accidentally fitting the wheels in the wrong orientation will result in the symptoms you described.
Hmm. I looked for bevels and didn't see a difference on either side. I will look again. Thanks for the help.
What is it about the winding and setting that doesnt feel right ? Is the spring working to return the rocker plate smoothly ?
Sorry for the same questioning, further replies are not always shown for some reason until after i answer the initial question. Quite frustrating , possibly a problem with the forum site , its happened a few times now.
HectorLooi is correct one side of the teeth have a chamfer. All the gears should be the same orientation of facing downwards when the rocker plate is installed.
  • 4 weeks later...
Alright I finally got a new ratchet wheel in as well as a donor balance. The donor balance had a broken pivot but the hairspring looked ok to me so I switched it to replace the original. I believe I am ready to re assemble this thing. I was thinking about doing a post on the reassembly but wasn't sure what specific steps would be valuable to anyone. Should I do a re assembly post?
    • I have removed the stem and open the case. The Movement can't drop out but it can be rotate Anyone has idea THANK YOU
    • Not a family member, and yes, it no way near as good, as some information got lost from original site and some information got incorrectly copied. The original site is available as iOS app here: https://apps.apple.com/fi/app/ranfft-watch-movements-archive/id6502008939
    • Outstanding, Marc! Your information is really helpful and clears this up, especially given that yours were purchased as sets. Thanks, man. So, it appears I jumped the gun on this one, but I am relieved. I will say, though, that all of my reamers and concave pushers are number-stamped and appear to be of better quality.  Also, the bayonets on my pushers are actually the same color as the steel.  The next thing to do is restore the heads of these pushers with some polishing paper.  Alex at the Watch Repair channel has a nice little video on this.   I appreciate your help! Frank
    • Just installed it on my iPhone (my only iOS device) and it appears to be intact and functional. I may have to go out and buy myself an ipad just for this app.
    • I have two Seitz sets, one ancient (with the 3mm anvils) and one just old (with 4mm anvils) plus a collection of spare pushers of assorted vintage. Not one of them is marked with it's size. Something which I have found very irritating when I have been using the tool and not returning pushers to their correct place in the tray every time as it means that I have to get the calipers out and measure them. These were bought as sets and collectively I have over 100 pushers so it would seem highly unlikely (if not inconceivable) that they are all cheap knock offs, especially as they are old enough to pre-date the prevalence of the Chinese knock off industry (at least as applied to watch making tools). I therefore believe them to be original Seitz parts. And there is no numbering. The shape of the bottom of the pump pushers is the same as your photo. The only thing that may not be the same is that the slotted insert (looks like a screw but is in fact a bayonet) should be brass. Yours looks the same colour as the steel but that could just be the lighting.
