Hi All, I have just serviced two Seiko Bellmatics, one is fine but the other one has developed this fault whereby the hands keep going out of sync with the date change. the first time it happened i thought it was my error as after 2 days the date wasnt changing until 9:30 AM so i reset the hands to 12 and again after a couple of days it did the same thing but wasnt changing until 7:30 AM, I reset the hands again and sure enough it is now out of sync again and not changing until 1:30 AM. The hands are not loose as it keeps spot on time, I have checked for anything sticking and manually followed the date change on the crown which is all fine, the quickset day change on the alarm button is fine as is the date change manually on the crown. I have even taken the working one apart and compared them but can see nothing wrong. This has got me stumped any advice would be appreciated. I have uploaded a pic of the faulty movement incase anyone can see anything. Thanks in advance. Tony
The only reason I can imagine for hours and calendar getting out of sync is a faulty meshing of gears between hour wheel and date wheel (a bit complicated with this caliber).
Edited by Kalanag
 I'd be surprised if the good one doesn't start  misbehaving soon. Out of sync complications is the hallmark of Seiko.
I would set the date to change couple of hrs before the 24th hr and hope for the best.
Down in my neck of the woods we call Seiko imprecise gears  "diesel  massey ferguson". 😩
Your post is assuming, opinioned and of no help. If anyone will find it amusing, at least will have served a purpose.
  • Sad 1
But I have been helpful, a trick to reduce the out of sync error.
The error is not accumulative here?   is it?
Regds
thanks, i have reset it again but not cased it, if it goes out again i will check that as it would make sense.
Regds
thanks i will keep that option on the reserve list lol.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
